Results 1 to 7 of 7
    Veteran Member Three Rings betyouaint's Avatar
    Mar 31 2010
    2016 Chevy Silverado Z71
    Wherever I lay my hat...
    Engine related sound. Almost sounds like the engine beeping?
    I pulled up to the drive-thru window at McDonalds last night and it sounded like there was some kind of alarm going off somewhere. Then I realized it was my car making the noise. It was really quite loud, even with the hood/bonnet closed. I drove home and recorded a couple of videos. You can clearly tune into the repetitive "beep" after around 15 seconds in the first video.
    http://www.youtube.com/watch?v=1m8uG...ature=youtu.be
    In the second video you can hear the "beep" smooth out into a whine as the engine is revved. Unfortunately, in this second video the sound isn't very loud.
    http://www.youtube.com/watch?v=-XSNy...ature=youtu.be
    To me, it sounds loudest on the left side of the car (the right side in the video) and towards the back of the block. Could it be the high pressure fuel pump maybe? The car is just coming up to 90,000 miles.
    Any other ideas?
    2006 Audi A4 2.0T Quattro Tiptronic - Now over 240k but still ticking along...
    Veteran Member Three Rings schmiesus's Avatar
    Jul 25 2011
    BC
    I assume no engine codes
    2007 A4 S-Line TI Brilliant Black - .......Not Stock
    Bought Not Built, Build!
    Jul 25 2011
    BC
    smooths to a whine? last time cam follower was checked? Flapper motors?
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    It look it's coming from the rear or engine, but i guess that depend where the mic is on the cam.
    I would says pulley bearing or around the acc belt or like you say HPFP. The frequency sound like an alarm. What did you changed on engine recently?
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Mar 31 2010
    No engines codes.
    I've had the car since 32,000 miles and there was some prior maintenance done that involved something cam related. Don't recall exactly what but I'm sure I have record somewhere. Is it an easy thing to check? Flapper motors? Not familiar with that item.
    No belts at the rear of the engine. Unless the sound is playing tricks in the engine bay, I'm fairly sure it's not at the front near the acc belt or pulleys?
    It did go into the dealer around 8 months back for an engine light. That may have been a sensor, maybe even a cam sensor. They also carried out a couple of outstanding TSBs on the PCV and airbox...?
    Veteran Member Three Rings baldy's Avatar
    May 11 2010
    Aprilia RSV4RF, Yamaha R1, '15 A3 TDI
    BC
    Vacuum pump?
    C7 A6 TDI - TurboSystems 2872..Wagner IC..CGQB fuel system+MAF..RS6 intake..Eurocode sways+inserts..Eibach springs..H&R 15mm spacers..JXB support..Powerflex diff inserts..Waxedshine PPS...OE hitch..HBA retrofit
    Oct 14 2009
    Okinawa Japan
    Sounds like a whistle, almost like a vacuum leak.
    I would check all of your hoses and intake system for any hoses misplaced or off.
    Do you have a boost gauge? I'm assuming not since you are stock, so you may not even have noticed a drop in performance, especially if it has happened over time.
    Though it could also be a bearing or tensioner, it's really hard to tell with your video
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
