Results 1 to 19 of 19
Thread: Kleen Flo 700?
    Jul 29 2007
    Toronto, ON
    Kleen Flo 700?
    Gents,
    Working with my aftermarket warranty company and our local Audi Dealership. Car is burning oil and the warranty company suggest using this product: http://www.kleenflo.com/en/productpages/700.htm
    The adjustor at the warranty company says this:
    "I’m really surprised that they don t know about the engine flush or else they never practiced it in their shop . the engine flush is provided by many different companies . the most common product is the kleen flow / 700. Sometimes dealers don t do this test because the result is not guaranteed, maybe you need to ask someone else to do the engine flush and retest for the oil consumption after.”
    The dealership says this:
    "This is not something we do. We don’t have the equipment as it’s not a sponsored practice for Audi."
    Thoughts???
    2006 Black S4
    AZ Members' Properties Bought/Sold: 6
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Seafoam instead.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Veteran Member Four Rings morris400's Avatar
    Dec 18 2008
    2016 VW GTI, 1994 Audi S4
    Alberta, Canada
    For a b5 s4 I'd say no. If your burning oil I don't think this will help you anyway.
    IF YOU WONT STAND BEHIND OUR TROOPS....TRY STANDING IN FRONT OF THEM!
    2016 VW Jetta 1.4T Daily Driver
    1994 Audi S4 20V Turbo, K24 7400 EFI EXPRESS
    2001 Audi S4 - Gone! Dropped valve cyl 4
    Dec 18 2008
    Alberta, Canada
    Quote Originally Posted by Timtheguru View Post
    Seafoam instead.
    This...
    Dec 30 2009
    Honestly though, they are probably trying to get you to use that so that Audi will say "WTF did you do to your engine!" Then the warranty company will not pay you since you caused the damage by putting that stuff in. The warranty company doesn't get to tell you how to fix it, they just give you money.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Oct 06 2011
    Audi S4 /Wifes 2011 cruz..bleh
    Southwest Michigan
    If it's the 2006 in your signature I would pull the plugs and have a look at the cylinders with a boroscope and do a compression test. The 4.2 engines are known to have occasional cylinder scoring and oil consumption issues. I would skip the motor flush more chance of problems than it's worth.
    Veteran Member Four Rings 1gcrazy's Avatar
    Sep 01 2011
    Colorado Springs
    Quote Originally Posted by ChrisGS4 View Post
    True story.
    Jul 29 2007
    Toronto, ON
    Re: Kleen Flo 700?
    The service rep and I think this is the issue. Maybe I should just pay for the boroscope and compression and get to the bottom of it.
    I'm on my phone. Sorry if I posted this in the b5 section (I miss my nogaro)
    2006 Black S4
    Established Member Two Rings budda's Avatar
    Mar 10 2010
    2000 S4 6M GT25 SOLD, 1990 Accord H22 GT35R w/JRZ RS Pro's, 2013 S4 GONE, 2016 S6
    This:
    http://motul.speclube.com/products/a...-diesel-300ml/
    It's probably one of the only engine flushes that actually works. Have used this before many times and have had oil tests done after to confirm that it doesn't cause engine wear. It has TUV (3rd party testing) approvals in Germany to prove it actual does what it claims to do,. unlike 99% of the other crap out there.
    If you are going to use an engine flush, this is the one to use
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Quote Originally Posted by qwks4 View Post
    Gents,
    Thoughts???
    Your warranty company is pure shit. If you are consuming oil, it's because you have leaky gaskets/turbos/piston blow-by (or something else inside the cylinder). Running an oil cleaner will not help the problem at all, and if there is a small amount of sludge lining where the leak is, it could make it worse. They are just trying to get out of paying. Call them on their bullshit.
    Jul 29 2007
    Toronto, ON
    I asked that if I paid for a boroscope & compression test, and results showed scored cylinder walls or damaged piston rings, if they would pay for the diagnostics and if the repairs would be covered under my warranty.
    Here is the reply:
    "Yes correct, if there is no issue, or an issue not covered under the warranty, you pay the mechanic. And, if there is an issue, and it is covered under the warranty, we pay the mechanic. Also, if there is wear/scoring/damage to the cylinder walls I would have to double check with our adjustor but this would usually mean a new engine or partial rebuild. As for the damage to the piston rings, I’m pretty sure you can just replace these, but again I would have to double check with our adjustor. Pictures to substantiate these damages would be needed. "
    My local Audi Dealer already said if it's the cylinder walls, it's a new engine. Audi doesn't suggest rebuilding.
    My question to AZ, and particularly anyone with experience dealing with a warranty company: If the company says it's a rebuild, but Audi says it should be a new engine, how do I push the warranty company to do an engine instead of a rebuild?
    2006 Black S4
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    I would not use that stuff at all.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Established Member Two Rings brndll's Avatar
    Jan 24 2011
    Plan0, Texas
    My wife works for a Roadside Assistance management company and they see these "products" get pitched every week. Its a shady business they (product sales guys) do and they will definitely not back up any damage done by the use of these products. Thier support extends as far as getting you to sign up for thier program. Stay away. Your Audi dealership (and I dont always trust them either) is trying to gently steer you from using these products which is the right path.
    If you think you have things under control... you just arent going fast enough -Mario Andretti
    Apr 24 2009
    Frisco, TX
    These products are like an atom-bomb. An engine that has seen any semblance of regular maintenance should never need this. These are for abused motors that got extremely crappy oil or are notorious sludge-monsters (1.8T, for example). Since these cars require ACEA A3/B4 synthetics (VW 502/505), those oils already have excellent cleaning and anti-varnish properties.
    Products like Seafoam, Kreen, and this can do more harm than good -- you'll suddenly loosen up a ton of shit and then it starts circulating through the filter, oil galleys, pickup tray, etc. Sometimes it's better to just leave a bit of varnish. Varnish is not really a bad thing and all motors develop it over time.
    Senior Member Three Rings Dirtracer603's Avatar
    Aug 15 2012
    Custom stunt CRF250 supermoto, 06 CBR600rr
    Fredericksburg, Va
    Quote Originally Posted by morris400 View Post
    ^ Exactly. Is usually 1 or more of the following: Poor ring seal, improperly functioning PCV system, worn valve seals.
    Oct 06 2011
    Southwest Michigan
    The cost of parts and labor on a proper rebuild will come out close to the price of a short block I'm willing to bet. The aluminum blocks are finished with a laser hone and it is probably why Audi does not recommend a rebuild.
    Definitely push for a new engine if yours is damaged. If you want to be a nice guy a used dealer inspected engine with a full timing service wouldn't be all bad either. It won't be cheap either way but they need to provide the service you paid for.
    Apr 24 2009
    Frisco, TX
    Alusil blocks can be machined, but it requires very specialized equipment and processes.
    Established Member Two Rings nugen's Avatar
    Jan 02 2010
    Long Island
    This is BS. As Blackstone pointed out to me, if these additives were so good they would come from the factory with it. Rubbish. Buy better oil or something.
    B7 S4 - JHM tuned, piggies, Carbonio intake...and some other stuff.
    B5 S4 - Stage 3 - Gone but not forgotten.
    Mar 05 2012
    Mazda RX8 GT
    south florida
    rule of thumb i've learned over the years and with several cars. "Only put oil where the oil goes", other fluids/additives dont belong there.
    B7 Sprint Blue Audi S4
    Few mods here and there
