Results 1 to 19 of 19
    Established Member Two Rings 407guy's Avatar
    Dec 05 2012
    2015 HD Sportster 48
    407 area code
    8.5 to 9.5 width on same tire question....
    (Yes, this is posted in the tire & wheel forum but I'm not sure on the traffic there so I'm giving it a shot here....)
    Here is my question:
    We have the 19x8.5 +35 wheels on our 2013 S4 (B8.5). Tires are 255/35-19.
    We like the look of the sidewall (height) and how it “fills” in the fender gap. [Sorry, only way I know how to describe it.] We aren’t fans of the actual OEM wheel though.
    If we went with a 19x9.5 +45 offset wheel and kept the OEM tires (255/35-19), how much will the “stretch” lower the sidewall height?
    I hope I’m describing what my concern is.
    We just don’t want to go with a wider wheel with the OEM tires and make the combo look “lower profile” since the tire has to stretch to fit the 9.5 width.
    8.5 to 9.5 has got to create some visual differences, no?
    Thanks.
    2013 B8.5 S4 | Ibis White Premium Plus | S tronic | AWE resonated downpipes and exhaust | VMR 721 19x8.5 (gunmetal)
    Jan 31 2012
    Delaware
    It will have a minor stretch, if you look in the modified wheel and suspension thread at the top of the forum there are a ton of pictures in there. Some people dont mind the minor stretch and it will help avoid rubbing the fender, but some people hate it. It also depends on the tire you put on the wheel. Michellin tires are more square with less visible stretch for a 255 while others are not as square. If you go on tire rack and click on potential tires for your rims it will give you all of the dimensions (tread width, contact patch all that stuff) and you will see that some are slightly bigger than others sometimes by up to .5 inch.
    There is also another thread floating around about putting 265's on a 9.5 wheel, do a search.
    2011 Premium Plus S4: 6MT, Meteor Gray, Silver Alcantera, Brushed Alum, Nav, B&O, Sport Dif, AG M510's 19x9.5, Hankook V12s
    Mods: G.I.A.C/AWE StgII Pulley Stock/93/100 tune, AWE Exhaust, AWE S-FLow, AWE Vent Gauge, AWE Boost Tap, H&R Coilovers, H&R Sways, Valentine 1
    Dec 05 2012
    407 area code
    Thanks. I have been looking. My challenge is most have (1) dropped the car so I don't know how 9.5 will look on factory height and/or (2) that thread doesn't always list the specs -- wheels and tires. Nothing you and I can do abotu (2), just isn't helpful for me.
    Veteran Member Four Rings 13S4's Avatar
    May 03 2012
    NA
    Stock is 19" wheels are 19x8.5 ET 43. Not ET 35.
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Quote Originally Posted by 407guy View Post
    Thanks.
    Yes - ask and ye shall receive....
    Here's a 255/35/19 Michelin Pilot Super Sport on the OEM wheel:
    And here's the same tire on a 9.5" wide VMR 710 wheel:
    Not only did I not like the looks of the tire on the wider wheel, but the performance would have likely been compromised, too, due to the sidewall and shoulder tread blocks not being oriented in the way that Michelin intended.
    I sent the 9.5s back and got 8.5s instead.
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Jul 19 2010
    Boston
    Quote Originally Posted by 13S4 View Post
    19x8.5 et 35 or 40 dropped on oe springs which one would be better would i be rub free with et35?
    thanks
    Dec 05 2012
    407 area code
    Really?
    I've been reading all over the place that it's 35.
    *shrug*
    We have the "5-segment-spoke-design alloy wheel with 255/35 summer tires". (Taken from audiusa.com.)
    Dec 05 2012
    407 area code
    Quote Originally Posted by zcd2.7t View Post
    SOLID!
    Thanks for the pix. That is our concern too, how much handling may be compromised.
    And also how much of the wheel lip is exposed for damage/rash. I've read how guys have bent wheels with normal everyday driving after stretching a tire to fit a wider wheel.
    Veteran Member Three Rings jfabes's Avatar
    Feb 05 2012
    H-town
    1) you won't see the stretch looking at the car from the sideas it deosn't change the wall height really (profile), you would only see it looking from the front/back angle wrt the rim edge. 2) 99% of people have no idea what a small amount of streth looks like (and this is really small), so unless you have the two back-to-back like above, it will go unnoticed. 3) you will never see the effects of handling on the street even if you push the car hard. take it to the track...maybe...but still have to be a skilled driver to discern the difference. there are way more important things to cconcern yourself with for tracking than this small amount of stretch, i.e springs, shocks, sways, end links, AK, etc.
    2012 S4 Prestige 6MT | Ibis / Spectra Silver Nappa | Shades | Sport Diff | SC Badges | APR Stage II+ v2 | Strat/Roc Intake | AWE Exhaust | H&R OE Sports | 19" x 9.5" Forgestar CF10's | Xpel Clearbra | 30% Metalized Tint | Carbon Fabric Interior Trim | OEM License Plate LED's | Drivetech Interior LED's | VCDS Mods
    May 03 2012
    NA
    Quote Originally Posted by mr_coo168 View Post
    thanks
    I'm pretty sure the stock 18's are 18x8" et 35?
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    Quote Originally Posted by jfabes View Post
    this. those PSS 255 on a 9.5" is BARELY stretched. it will NOT affect your handling negatively in any way. 255 is perfectly suitable AND in the manufacturer's range for a 9.5" wheel.
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Dec 05 2012
    407 area code
    Understood but a picture is worth a 1,000 words.
    See zcd2.7t's pictures above...
    Just my preference to stick with a 8.5" width.
    Established Member Two Rings lmwong's Avatar
    Aug 21 2008
    Earth
    Really?
    *shrug*
    That's the tire sidewall height, 35, not the ET, which is 43.
    As I've been looking for wheels myself, I've found this calculator to help me out. Stock peelers are 19" 8.5 ET43. Stock wheel is 255/35/19.
    2011 Audi S4 Prestige | Deap Sea Blue Pearl | Tint | H&R OE springs | Lamin-X and yellow fog bulbs | RS4 grill painted silver | ROC-intake | BT aux input | WINTER: Bridgestone Blizzak LM-60 255/35/19 on stock peelers & 5 mm BFI rear spacers | SUMMER: Michelin Pilot Super Sport 255/35/19 on AluFelgen SF-71 19 9.5 ET42
    Sep 16 2008
    well aesthetics are subjective, haha. looks good either way! the very slight stretch will allow you to push the wheels out farther giving you a more flush look, which i am a fan of.. but i also love a nice meaty setup!
    PREVIOUS:
    Jan 31 2014
    SF Bay Area
    I have been been tracking/competing in time attack events in my S2000 for a few years now. Ive been able to test quite a few different setups and would like to believe Im pretty knowledgable on the subject. Im seeing some misinformation in this thread. To be clear, running a wider wheel (to an extent) for a given tire width actually increases its performance, not decreases. So dont confuse stretching a proper tire width with the crap that the "stance" or "hella flush" crowd do
    There are many reasons to run a tire slightly stretched for performance related reasons. Im too lazy to type my own explanation so Ill steal one of Emilio Cervantes' (Owner of 949 racing/NASA record holder at many tracks in California). He stated, "Lateral acceleration is only produced when one or both sidewalls are under tension. You turn the wheel, the contact patch lags behind as the sidewall winds up and tensions. With a wheel tire combo that allows the casing to roll back and forth or the tread area to twist relative to the wheel centerline, you have some lag time before there is a change in the vehicle's lateral acceleration. Widen the wheel to the point that both inner and outer sidewalls are always in optimum tension and you reduce the time needed for any steering input to effect a change in lateral acceleration. So quicker and more linear response turning in, making corrections mid turn, throttle inputs, etc.
    The greater air volume from using a wider wheel allows lower air pressure to carry a given load. This lower air pressure allows the tread and sidewall to more easily conform to irregularities in the pavement, which increases grip.
    The spring rate of the tire is also slightly lowered. This lower tire spring rate can be good or bad, depending if the tuner has compensated for it with in tuning everything else. The combination of spring rate and more deformable casing can allow a properly tuned suspension to reduce contact patch load area variation. That's the tiny little fluctuations in loading on any given part of the contact patch. Ideally, you want the contact patch loading always right at optimum to achieve maximum grip. In exaggerated terms, that's skipping across the pavement or smoothly rolling/sliding.
    If you have any experience testing radials, you will already know that they will be fastest on a wheel roughly the same width as the casing, not tread. This does not change with sidewall stiffness."
    This last part is what a lot of track guys have been starting to figure out. Take for example the (nominal) 255/35R19 tire mentioned in this thread, theoretically it should be 255mm wide, 255mm=~10". Therefore the wheel that it would produce its fastest lap times on is a 10" wide wheel. This has been proven with lap times for the past few years.
    The same tire on say the stock 8.5" wheel is to have increased comfort (allows more compliance)... which is why Audi gave everyone a "narrow" wheel for the stock tire size.
    Veteran Member Three Rings mmmkam's Avatar
    Sep 29 2013
    NoVA
    Quote Originally Posted by staticuxo View Post
    +1. If you look at the tire specs on tire rack most 255 tires are speced out on a default of a 9" wheel, but will fit anything from a 8.5"-9.5" or even 10" wheel in some cases. Check the "measured rim width" which should be a 100% flat side wall. In those cases (just about all of them) where 9" is the measured rim width on an 8.5" wheel there will be a minor pull IN and at 9.5" or higher gives a minor stretch out. To your point depending on the wheel and tire combo the edge of the wheel will become more and more exposed the more stretch you put on the tire so be cautious around the curbs.
    The pics posted above are a pretty accurate representation with the PSS. I posted some pics of mine at stock height with 9.5" rims and 255 Blizzark LM32 tires witch look slightly more stretched if you search.
    My recommendation if you don't plan on lowering and like the stock look/profile of the tires is to stick with an 8.5" rim @ ET40 (close to the stock ET43) or at most 9". On mine even with the minor stretch of 9.5" and the flush sitting of ET 40 at that wheel size it just cries out for a drop to me visually although to date everyone that sees it and drools.
    2014 S4 6MT | Estoril Blue | Prestige | Sport diff | Carbon atlas inlays | ADS | Alu-Optic package | Fine Nappa Black/Silver | Pwr Sun Shade | 19" Peelers | AG M590 19x9.5 ET40 | Xpel Ultimate | Gtech Coating | WeatherTech Floorliners | RS4 Grill w/ Matte Silver Surround | AWE Resonated Exhaust | Revo Intake | AWE Pulley | GIAC Stage II Tune | EC Shifter | EC Alu Kreuz
    Senior Member Two Rings IceSilverS4's Avatar
    Jan 06 2014
    2012 Audi S4, 2013 Tiguan R-Line
    Blainville, QC, Canada
    Thank you for the quote, very instructive !
    Quote Originally Posted by MMisencik157 View Post
    ... so Ill steal one of Emilio Cervantes' (Owner of 949 racing/NASA record holder at many tracks in California). He stated, "Lateral acceleration is only produced when one or both sidewalls are under tension. You turn the wheel, the contact patch lags behind...
    Sold - 2012 Audi S4 - Ice Silver - Magma Red
    Senior Member Four Rings Skywagon's Avatar
    Dec 19 2013
    North Carolina
    Tire Rack web site says those tires will work on 8.5 to 10.0 inch wide wheels.
    http://www.tirerack.com/tires/tires....XLV4&tab=Specs
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    157s information is spot on. One of the key words is the "slight" stretch. As with anything to much of a good thing can be bad. When I campaigned a car in SOLO2 seriously we would measure the width of the tire bead and match it to the width that is just slightly wider for the reasons mentioned above. You could feel the difference on turn in and through the slaloms.
    You also need to consider what do you want to get out of your tire and wheel package. Is this setup going for max performance, looks or just to do what a normal tire does. When I do my setup, plan on 19x9.5 because I want some concave, I am going to go with a 265 tire. I want to protect the rim, incase I get to close to a curb. I personally also do not like the stretch look, just a personal choice.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
