Originally Posted by
jibberjive
Why do you want to return to the Y-pipe when there's vacuum in the manifold? Why not simply return to the manifold when there's vacuum in the manifold, via a simple check valve like stock? That line a check valve is sized to flow what the engine is supposed to under those DD-type vacuum situations. Also, regarding venting to the atmosphere rather than Y-pipe vacuum under boost, that's a terrible idea, like rtl5009 said. These cars suffer from an undersized PCV tract that is too small for upgraded power as-is, and removing that one connection is like cutting the PCV's only leg out from under it. That's like putting huge turbos on a stock 2.7t and only installing 2 of each mains 4 bolts to save weight; you want to do what you can to help relieve more of the crankcase pressure, not exacerbate it.
You've got the provent to remove the oil from the air, so don't worry about oil getting into the combustion process (have you checked your Y-pipe and IC's since installing the Provent and it's still sucking oil into the intake tract?). You've got the Provent 200 I assume (as the 400 is physically huge and I can't imagine where you'd stuff it in the cramped 2.7t engine bay. edit: oh yeah, forgot you're an allroad)? If you've got the 200, that adds two more strikes against the proper flow of the blowby gasses, as the provent, though effective at removing entrained oil, is a filter-type separator, which inherently has appreciable pressure drop across the filter media. Also, the 200 is undersized for the power and flow that you're going to be running with your 770's. So your PCV needs all of the help it can get rather than taking away it's main vacuum source.
I currently have, forget exact size of hose, whatever slips OVER valley and both valve covers PCV ports (I am thinking 3/4" ID) merging in the middle to 1" ID hose going to provent 200. Outlet is 1" going over y-pipe nipple. I am not worried about provent 200 not keeping up with blow by gases under boost, I am ok with it not filtering the gases anymore as it has pressure relief valve built in that diverts them directly to outlet... last resort is oil cap pressure relief valve. System is more than sufficient as is... But.
I know that it is robbing me from some HPs as the spent gas (no oxygen in it!) must be sizable during high boost pulls. This gas is HOT, needs to be compressed by turbos and yet it contributes ZERO to making power, it is actually a lost opportunity for legit oxygen to enter the system in its place and make power.
So that's why I am looking for ideas here...If a switch of some sorts can be installed to divert gases somewhere else, then a road draft tube can be installed to provide some vacuum.
Edit: Just checked, provent will actually relieve the pressure by venting outside, not directly to outlet.
