Receive everything required to perform the highest quality timing belt replacement in your Audi / VW 1.8T AEB & ATW engine.
All parts in this timing belt kit are OEM (or better) quality and TüV/ISO 9001 certified. Our team carefully selected and tested every part to ensure the perfect fit and quality. Your satisfaction is 100% guaranteed.
You can customize this Audi / VW timing belt kit to fit your specific needs. Just use the checkboxes below to select or de-select the kit components.
ESSENTIAL Timing Belt Kit Components:*
- 1 x Timing Belt (1.8T, AEB & ATW) (Continental, 058109119C)
- 1 x Timing Belt Tensioner (1.8T, AEB & ATW) (NTN, 058109479B)
- 1 x Timing Belt Tensioner Roller (1.8T, AEB & ATW) (Febi Bilstein, 058109243E)
- 1 x Timing Belt Small Idler Roller (Mk4 TDI ALH/B5 1.8T) (INA, 058109244)
- 1 x Water Pump (AEB & ATW) (Graf, 026121005L)
- 1 x Thermostat (87C) (Genuine Audi VW, 050121113C)
- 1 x A/C Drive Belt (Continental, 06B260849A)
- 1 x Power Steering / Water Pump Belt (AEB & ATW) (Continental, 058145271)
- 1 x Accessory Drive Belt (Continental, 06B903137E)
- 2 x Camshaft Seal (47x10x32) (Elring, 038103085C)
RECOMMENDED Timing Belt Kit Components:
- 1 x Genuine G12 Plus Plus Engine Coolant (1 Gallon) (Genuine Audi VW, G012A8G1G)
- 1 x Timing Belt Service Sticker (Genuine Audi VW, 059010158A)
Timing Belt Kit (A4 B5 1.8T, AWM, Early VIN)
This is, hand-down, the most high-quality and complete OEM certified timing belt kit for A4 B5 1.8T (AWM engine code, Early VIN) engine on the market. We have put in a lot of research and testing into each part (and manufacturer) to make sure that you receive everything required to perform the best timing belt job on your A4 B5 1.8T (AWM engine code, Early VIN) engine.
This timing belt kit fits:
Audi A4 B5 1.8T (AWM engine code, Early VIN)
Important: This kit fits models up to VIN 8D-1-042 384 on AMW engine codes. Split is in the 2001 model year.
Why you should buy your Audi A4 B5 1.8T (AWM engine code, Early VIN) timing belt kit from us:
- All parts in this timing belt kit are OEM (or better) quality and TüV/ISO 9001 certified
- Our team carefully selected and tested every part to ensure the perfect fit and quality
- You can customize the timing belt kit components to fit your needs (or just go with our recommendation)
- Your complete satisfaction is our highest objective.
Feel free to contact us if you have any questions about this Audi A4 B5 1.8T (AWM engine code, Early VIN) timing belt kit. We look forward to hearing from you.
- 1 x Timing Belt (1.8T) (Continental, 06B109119F)
- 1 x Timing Belt Tensioner (1.8T, w/Idler) (NTN, 06B109477)
- 1 x Timing Belt Tensioner Roller (1.8T) (NTN, 06B109243F)
- 1 x Water Pump (1.8T, 2.0, Metal Impeller) (Geba, 06A121012G)
- 1 x Thermostat Housing (1.8T, AUG/AWM) (Genuine Audi VW, 06B121121L)
- 1 x Camshaft Seal (47x10x32) (Elring, 038103085C)
- 1 x Crankshaft Seal (35x48x10) (Elring, 038103085E)
Timing Belt Kit (A4 B5 1.8T, AWM, Late VIN)
This is, hand-down, the most high-quality and complete OEM certified timing belt kit for A4 B5 1.8T (AWM engine code, Late VIN) engine on the market. We have put in a lot of research and testing into each part (and manufacturer) to make sure that you receive everything required to perform the best timing belt job on your A4 B5 1.8T (AWM engine code, Late VIN) engine.
Audi A4 B5 1.8T (AWM engine code, Late VIN)
Important: This kit fits models from VIN 8D-1-042 385 on AMW engine codes. Split is in the 2001 model year.
Why you should buy your Audi A4 B5 1.8T (AWM engine code, Late VIN) timing belt kit from us:
Feel free to contact us if you have any questions about this Audi A4 B5 1.8T (AWM engine code, Late VIN) timing belt kit. We look forward to hearing from you.
- 1 x Timing Belt Tensioner (1.8T) (NTN, 06B109477A)
- 1 x Timing Belt Tensioner Roller (1.8T) (NTN, 06B109243E)
Timing Belt Kit (A4 B5 2.8L V6 30v, Early VIN)
This is, hand-down, the most high-quality and complete OEM certified timing belt kit for A4 B5 2.8L V6 30v (Early VIN) engine on the market. We have put in a lot of research and testing into each part (and manufacturer) to make sure that you receive everything required to perform the best timing belt job on your A4 B5 2.8L V6 30v (Early VIN) engine.
Audi A4 B5 2.8L V6 30v (Early VIN)
Important: 1998 Audi A4 came two different timing belt tensioners. Earlier A4 models had a 2-bolt style and later models come with a 3-bolt tensioner. This kit includes the 2-bolt tensioner. Up to VIN 8D-W-007 799, split is in the 1998 model year.
Why you should buy your A4 B5 2.8L V6 30v (Early VIN) timing belt kit from us:
Feel free to contact us if you have any questions about this A4 B5 2.8L V6 30v (Early VIN) timing belt kit. We look forward to hearing from you
RECOMMENDED Timing Belt Kit Components:*
- 1 x Timing Belt (V6/V8) (Continental, 078109119J)
- 1 x Tensioner Roller (NTN, 078109243S)
- 1 x Timing Belt Roller (INA, 078109244H)
- 1 x Timing Belt Tensioner (2-Hole) (INA, 078109479B)
- 1 x Relay Tensioning Lever (NTN, 078109487C)
- 1 x Accessory Drive Belt (21.36x1882mm) (Continental, 078903137BC)
- 1 x Water Pump (Metal Impeller) (Geba, 078121006A)
- 1 x Thermostat (92 Celsius) (Behr, 078121113G)
- 2 x Camshaft Seal (47x10x32, Spring Type) (Elring, 068103085E)
OPTIONAL Timing Belt Kit Components:
- 1 x Accessory Belt Tensioner Assembly (INA, 078903133AB)
- 1 x Snub Mount (1.8T/2.7T/2.8L) (OE Manufacturer, 8D0199339P)
- 1 x Loctite Threadlocker 242 (Medium, 6 ml) (Loctite)
OPTIONAL Timing Belt Tools:
- 1 x V6 & V8 Cam Locking Bar (Metalnerd)
- 1 x V6 & V8 Crank Locking Pin (Metalnerd)
- 1 x 2-Arm Sprocket Puller (Metalnerd)
Timing Belt Kit (2.8L V6 30v, Late VIN)
This is, hand-down, the most high-quality and complete OEM certified timing belt kit for 2.8L V6 30v engine on the market. We have put in a lot of research and testing into each part (and manufacturer) to make sure that you receive everything required to perform the best timing belt job on your 2.8L V6 30v Audi/VW engine.
- Audi A4 B5 2.8L V6 30v (Late VIN)
- Audi A6 C5 2.8L V6
- Volkswagen Passat B5 V6
Important: 1998 Audi A4 came two different timing belt tensioners. Earlier A4 models had a 2-bolt style and later models come with a 3-bolt tensioner. This kit includes the 3-bolt tensioner. From VIN 8D-W-007 800, split is in the 1998 model year.
Why you should buy your 2.8L V6 30v Audi/VW timing belt kit from us:
Feel free to contact us if you have any questions about this 2.8L V6 30v Audi/VW timing belt kit. We look forward to hearing from you.
- 1 x Timing Belt Tensioner (NTN, 078109479E)
