Results 1 to 15 of 15
    Oct 19 2012
    United States
    Tire Pressure Monitor System malfunction
    My TPS light is on, but I checked and all the tires have the correct psi. Will and Audi dealership clear the code for free if I'm out of warranty, or should I replace the system?
    Oct 13 2011
    2011 Jetta, 2004 R6, 2007 B7
    Nutley, NJ
    what year car?
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    You should just turn off the system via vagcom.
    Dec 11 2008
    '08 A4 Avant SE, '99 4Runner
    Westminster, CO USA
    Do you have the trip computer on the wiper stalk? You can store the new pressures via the menu.
    Oct 13 2011
    Nutley, NJ
    reset the system yourself. there should be a button
    Senior Member Three Rings turbowop's Avatar
    Dec 01 2012
    '91 Mitsu GVR4
    Yakima, WA, PNW
    RTFM
    -Mark
    '91 Mitsu GVR4 #1051 / 425awhp / 11.90@121mph / tuning and wrenching by me / full weight @ 3280lbs
    '08 Audi A4 2.0t 6mt Quattro / Ibis white / convenience & premium package / APR 2+ flash / APR exhaust / APR HPFP / 034 test pipe / CTS FMIC / Stasis street sport coilovers / RS4 rear swaybar / Thor undertray / Podi boost gauge / BFI snub /
    Thule ski rack / tint / paint matched reflectors / 19" Hartmann R8's on Conti DW summers / 17" stock split-5's on Dunlop Graspic winters
    Senior Member Three Rings pDubs's Avatar
    Jan 12 2012
    2005 Kawasaki ZX6R, 1973 Honda CB350F
    Fairfax, VA
    My b7 a4 doesn't have TPMS so I'm not sure but theres a possibility your spare has a sensor also and that is low, have you checked that? Are you checking the tire pressures when they are warmed up? If you have been driving on the tires and then check them they should go about 3-4 psi higher than what the recommended cold tire pressures are on the door. I doubt the tpms light would be on with only that though. The sensor could have just failed. I would have the dealer or a tire shop reset the sensors, it takes about a minute. If the light stays on you might just need to replace the sensor.
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    If you have a TPMS light and your pressures are good then something has failed and needs to be fixed. There's a reason you have a TPMS system. If you have run-flats, it's hard to tell when they're dangerously low.
    You'll need VCDS
    2005 A4 Avant 1.8t QTM
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    +1 on checking the spare!
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Established Member Two Rings redcon1's Avatar
    Oct 22 2009
    '99.5 GTI VR6, '13 Touareg Sport V6/FSI
    South Central PA
    TPMS failed this weekend on my 2008 Avant. There is a difference between the TPMS warning for low pressure, and the warning that there is a TPMS system malfunction. Mine is the latter and the display reads 'TPMS', along with the illuminated (!) tire symbol.
    I need to scan with VCDS but I suspect that the batteries in my sensors are dying, or the antenna located in the rear bumper is failing.
    I might go ahead and disable it anyway, I'm pretty anal about checking pressures and none of my other cars has TPMS.
    Dave
    2013 Touareg Sport V6 FSI
    2000 BMW Z3 2.3
    Veteran Member Four Rings two2's Avatar
    Jan 25 2009
    RS4
    Tri-state/CT
    to disable the TPMS don't you have to disconnect some module and also modify some VCDS setting, or is VCDS enough?
    Established Member Two Rings rubberband's Avatar
    Sep 18 2009
    B6 Quattro Avant ~ e46M3
    San Diego, CA
    you just need to disable via vag com. Nothing else is required.
    Liquor in the front Poker in the rear - Reverand Horton Heat
    Oct 22 2009
    South Central PA
    ENded up disabling the system with VCDS. Here's the instruction thread:
    http://www.audizine.com/forum/showth...highlight=tpms
    Dave
    2000 BMW Z3 2.3
    Veteran Member Four Rings slvrb7's Avatar
    Dec 28 2011
    2016 Polaris RZR 1000, 2016 Jeep Wrangler JKU, 2017 Range Rover, 2018 Land Rover Discovery
    North Texas
    have you gotten tint done recently? the TPMS chip is located under the back window on the sedans if you get water in there it will fry leaving you with the issue you have.
    Kris
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Quote Originally Posted by redcon1 View Post
    Good move. The system is useless, really.
