These first few steps have instructions that can be found on the web, or in the bentley; so I am not including pictures.
Step 1: Remove trunk lid.
Step 2: Remove interior trunk liners
Step 3: remove tail lights
Step 4. Remove Nuts holding on rear bumper cover; remove rear bumper cover.
Step 5: Remove rear bumper rebar.
Step6: With 60 grit sand paper, Lightly sand around the seams where the quarter panel appears to join with the body. This will help to reveal where the spot welds are that you need to drill. Look at the photo's below. You'll notice that the outline of circles start to appear in the areas that you sand.
Step 7: With a 1/8" drill bit, create a dimple in the center of the weld. The photo I took of this was blurry so I'll be repeating the following photo twice. Notice the dimple in the center of the circle that's been cut here. This will allow your spot weld cutter to remain in place. Do this for every spot weld that you've discovered by the sanding you did in step 6.
Step 8: Attach your spot weld cutter to your drill bit. You can purchase them at harbor freight
(clicky clicky).. but 2-3 of them. Put the center bit into the dimple that you just drilled. These are spring loaded, so press in firmly and begin to drill slowly... stopping every few rotations. You only want to cut through the spot weld, so if you have a parts car then be sure to practice on that first. You need the material to remain on the other side so that you can make a plug weld when you go to put the quarter panel onto your car. Do this for every spot weld.
Step 9: You'll notice that in some areas there are spots that look like there are long welds. A spot where this can be easily seen is along the trunk lid area and around the tail lights. These are actually not welds but a chemically bonded area. Space age Nasa Technology. If this was the only way the quarter panel was bonded then this would be a piece of cake:
Step 10: With a heatgun set for 1200-1500F, heat those seams. Take a large flat head screw driver and begin scraping. You'll notice that those seams will smoke like crazy; that's good.. means that the bond is breaking. Be sure to scrape into the crevice that is left behind as well.
Step 11: After you get the bulk of the bonding agent scraped off, take your screw driver and lightly wedge it between the quarter panel and body. I chose to keep using my heat gun to make it a bit easier. It should start easily seperate along the spot welds. If you look carefully you can still see some bonding agent where the tip of my screw driver is at, this is why you want to continue to use the heat gun.
This is how it should look. Don't pry hard... pry very lightly, you want this to retain it's shape when you go to put it on your car.
To be continued as time allows me to progress further.
