Originally Posted by
homegrowna4
Had my ac bypassed like this last winter with no problems. No idler or anything and the engine seemed to rev much smoother. I believe I used a Dayco 5060423.
The belt you are referencing is shorter than the one most people are recommending for the compressor bypass. Yet...that belt (the 450K6) seems a little too long for me...so maybe this shorter belt you mentioned is correct? Also, your photo is not showing up, so I can't see how you have the belt routed.
I'm a bit perplexed. Can someone confirm the part number and/or length? The 45-5/8" (1160mm) Gates belt that I have (K06040/6PK1146/450K6) seems too long. Either that or I have the routing
very wrong.
