Results 1 to 9 of 9
    Sep 07 2012
    Tucson, AZ
    Unhooking battery to clear DTC's?
    So I just finished doing some maintenance and fired the car right back up only to be greeted by a CEL. I have the unregistered version of vagcom so I checked it and had a misfire on cyl. 2. I swapped coil packs and found the wastegate hose clamp broke and was probably leaking. Replaced the clamp and tried unhooking the battery to clear the DTC's since I can't clear them with my unregistered version of vcds. I hooked the batt back up and checked the codes and they're all still there! Is there any other way of clearing DTC's without vagcom? The car seems to be currently in limp mode and will not boost over 5lbs. Any help would be awesome! This car is driving me crazy
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    Not gonna happen. I've gotten ecu's from the junkyard that had been disconnected for months that still had stored codes. There's plenty of shareware/freeware OBD software that'll work with your dumb kkl cable, try monoscan.
    Sep 07 2012
    Tucson, AZ
    You are a lifesaver man! Downloaded monoscan and checked, cleared codes, finally found a map sensor code that wouldn't go away. Looked under hood and found map sensor somehow got unplugged... Plugged it back in and got my beastly stock 8psi back! Wish I could buy you a beer right now.
    Veteran Member Four Rings 2.7taudi's Avatar
    Sep 08 2011
    Houston, Texas
    Quote Originally Posted by LightningLou View Post
    Disconnecting the battery will only remove the MIL temporarily. The MIL will illumanate once it registers the error is still present. ALL DTC'S stored in the ECU cannot be removed unless cleared or problem is fixed.
    I have the VCDS LITE version and im able to clear codes. Are you certain you cant clear codes? I dont even have the paid version of the VCDS LITE.
    Garage: 2001 A6 2.8 FWD 5AT & 2002 A6 2.7T 5AT
    Sep 07 2012
    Tucson, AZ
    Quote Originally Posted by 2.7taudi View Post
    Yeah man I can read codes no problem in vcds lite but when I try to clear them a popup comes up saying I must register before I can use that feature. Did you download online or use the disc that was sent with your cable? I just have a cheapo blue ebay cable. Regardless, monoscan worked like a charm.
    Sep 08 2011
    Houston, Texas
    Weird. I also have the Blue Cable. I got the VCDS from ross tech's website.
    Oct 14 2012
    Upstate NY
    Glad to be of assistance!
    Veteran Member Four Rings phila_dot's Avatar
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    Can't clear all codes from a scan, but you can clear them from the individual modules.
    Dec 05 2011
    Boston, MA
    You can clear codes on vag com lite. U go into another screen and click on engine and clear them individually in there.
