Results 1 to 15 of 15
    Established Member Two Rings AlphaMale's Avatar
    Sep 17 2009
    Upstate New York
    alignment place can't adjust camber
    Just like the title says. Recently took the B6 to Sears for an alignment after I noticed some steering wheel pull to the right and shakiness during all throttle conditions. Tech comes out and tells me the alignment is done but they couldnt adjust the camber on the front passenger side due to worn parts. He refused to tell me what parts. I was in a hurry and didn't have time to pitch a fit so I just left. Naturally, the car still shook and steering wheel still pulled to the right. Would this "diagnosis" give any indication as to what I might be looking at here? Upper control arms? Axle? CV joints look intact but its hard to get in there and look because there's a foot of snow outside and i have no garage/driveway.
    There's gonna be a lot of slow-singin' and flower-bringin' if my burglar alarm starts ringin'
    DG 05 1.8TQM 6-spd - APR 1+/Bosch TT225 386cc injectors/710N/podi boost gauge/APR snub/RS4 rear sway/n249 delete
    Jun 27 2011
    He's full of shit. You can't adjust camber REGARDLESS on the front.
    Did they even do anything? I bet you have a worn Tie rod and it was siezed. Hence the guy didn't touch it, made up some excuse, and charged you for him to twiddle his thumbs...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Registered User Three Rings Support@KMDtuning's Avatar
    Oct 01 2012
    North-East New Jersey
    The best way to adjust Camber in the Front of these cars is with Adjustable upper control arms! Try to find a shop that has a Hunter Hawk Eye Alignment machine! Also, make sure your tie rod nuts are not frozen!
    May 01 2012
    So caster only? why can't camber be adjusted? What would cause an inner tire wear then?
    Jun 27 2011
    Quote Originally Posted by AlS6 View Post
    Toe only, actually. Camber is static, its dictated by the Upper Control Arms. If you get adjustable uppers then you can adjust it, but otherwise you can't. You can shift the subframe around though if its not even side to side, but the total camber is set.
    Inner tire wear (something I have actually too) is caused by a combination of worn upper arms (causing a sag and the static camber increases as well as being unstable under loads) and excessive toe-in. Its tough to narrow down though as the wear levels of suspension components and the "sag" worn bushings can introduce can have varied effects...
    -CP
    2017 Q7 3.0t
    May 20 2010
    Sucks that they charge you. When I lived in NJ, the Sears I used to take my cars to didn't charge me when my tie rods were worn too much to adjust. Shame you got ripped off.
    Active Member One Ring Strunzee's Avatar
    Sep 27 2012
    1990 BMW 750il, 2004 Audi A6 4.2, 2007 Audi Q7 4.2
    Milwaukee/Wisconsin/Midwest
    i have a c5 allroad and i am also getting uneven tire wear on the rear tires, but there arent rear tie rods correct? what else could be causing it?
    Jun 27 2011
    Camber and toe is adjustable in the rear. I'm not positive with the C5 platform, but I believe its the same suspension design.
    -CP
    2017 Q7 3.0t
    Veteran Member Three Rings vjborelli's Avatar
    Apr 18 2012
    Boston, MA
    Re: alignment place can't adjust camber
    Camber can also be off if any of the car's previous owners installed the B5 spring perches. It lowers the cars front end a bit.
    Sent from my Banana Phone
    ST Performance Coilover Suspension, 18" VMR 702 Wheels, Unitronic HFC & 3" DP, BKR7EIX plugs, 2.0 TFSI Coil Packs, FrankenTurbo F21L, JE Pistons, IE Rods, ClutchMasters FX350 Clutch, ClutchMasters FW-027-SF Flywheel, Custom Tuning
    Jun 30 2008
    Erie, Pennsylvania
    You'll find that you get more specific suggestions if you post the actual alignment specs. I'm not sure if you have them in this case, though.
    Sep 17 2009
    Upstate New York
    Sent from my DROID X2 using Tapatalk 2
    Apr 18 2012
    Boston, MA
    Quote Originally Posted by AlphaMale View Post
    They just didn't want to adjust your subframe. Go get your money back.
    Overall, don't get your alignment at Sears. Their $75 alignment only has a 6 month warranty, and it is front end only.
    Jun 30 2008
    Erie, Pennsylvania
    Yeah. Right Front camber is nearly double that of the Left Front. I would say that is enough to warrant sliding the subframe.
    May 01 2012
    So if I replace the shocks in the front, I would not worry about alignment then if alignment is good to begin with?
    Apr 18 2012
    Boston, MA
    You always want to check it after any suspension or steering work. The Sears near me has a free alignment inspection machine that takes 5 minutes to check.
