Results 1 to 40 of 42
    Established Member Two Rings ThunderWuss's Avatar
    Nov 25 2009
    Spring Lake, MI
    Putting dexcool a bad idea?
    I was wondering if putting dexcool coolant in instead of the g12 would harm the vehicle at all? only asking because I have an unlimited free supply of dexcool.
    Apr 18 2007
    ny
    You might as well just use coffee.
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Don't.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Nov 21 2012
    Ohio
    Just never Mix
    Account Terminated Two Rings
    Feb 14 2011
    01.5 S4, 99 Tacoma
    Loyalton, CA
    The orange GM Dex Cool works great.
    Sep 18 2012
    State College PA
    Dexcool is perfectly fine.
    Its what I'm using. Its essentially the same as the German stuff
    They are both meant for aluminum and iron mixed engines to stop corrosion.
    Nov 25 2009
    Spring Lake, MI
    Thanks for your imput. I know the gm dexcool is really good stuff, just didn't know if it would mess with anything in these 10+ year old cars.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Can Dexcool and g12 be mixed or do you need to drain the g12 before filling with dexcool?
    Nov 25 2009
    Spring Lake, MI
    It's not recommend that any coolant be mixed. Anytime coolant is changed the vehicle cooling system should be completely flushed before exchanging fluids.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Cool thanks!
    May 16 2008
    South Texas
    I'd flush the system a few times, as the pink stuff can leave crystallized residue.
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    dont use dexcool.
    ever.
    RS6 hybrids and corn
    Active Member Four Rings
    Dec 11 2006
    Boston
    I've used GM Dexcool for years.
    Stage 3+ RS6's
    May 16 2008
    South Texas
    What does dexcool cost? A gallon of G12 is ~$25.00 and you have to flush your system every 2 years?
    Aug 02 2011
    RS4
    Baltimore
    Re: Putting dexcool a bad idea?
    I would use G12. I have seen nasty results from other coolants. It should be available locally from auto parts store (Pentosin brand) or oem from dealer.
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    A gallon is under $10 and thats full strength. Seen many lsx type engines torn apart and no internal issues with dex.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Senior Member Two Rings laserb5's Avatar
    Sep 30 2011
    B6 a4 1.8tqm avant (wifey's car)
    mid ohio
    That nasty sludge was not just the dexcools fault, that is sludge caused by mixing of coolants, seen it many times with many different kinds of coolant. If you make sure to completely flush the entire system including the heater core you won't have an issue. I have put 60k miles on my engine with only dexcool in it, just disassembled the entire engine a few weeks ago and there is not one bit of sludge in it. For the price difference it's unbeatable, ESP if you drain it often since you can fill the system for just a little more than one gallon of g12.
    Veteran Member Three Rings ElliottG's Avatar
    Apr 30 2009
    '12 Q5 2.0T
    edit..
    Aug 13 2008
    Indiana
    This is all anyone really needs to see. I'll have to show this to my techs at work.
    -Nic
    Veteran Member Four Rings jasonsowers's Avatar
    Feb 18 2007
    Denver, Colorado
    just flush the system if you are going to use it. If you mix coolants sometimes they get and it can lead to a huge pain in the ass.
    2002 B5 S4 Laser Red Avant - Tial 605 EPL tuned
    2000 B5 S4 Brilliant Black - Stage 3 K04/RS6 hybrid sedan EPL tuned
    2006 Cayenne Turbo - Stage 2 EPL tuned
    2006 Audi B7 A4 Avant 2.0t 6mt - Stage 2 EPL tuned
    2013 Phantom Black Pearl Effect 3.0t Q5
    2014 Monsoon Grey SQ5 - Stage 2 EPL tuned
    Veteran Member Three Rings Taloras's Avatar
    Jan 19 2011
    PDX
    Quote Originally Posted by jasonsowers View Post
    +1, been running dex-cool for like 20k miles now with no issues. As long as you flush out ALL the old stuff and don't allow any mixing at all, it'll be fine.
    Flushing ALL the old stuff=you've drained, added water, and run the car up to temperature enough times such that the last drain before coolant fill is clear.
    I run dex-cool not because it's significantly cheaper (a gallon of G12 every two years is not much at all), but because, if I ever need coolant on the road for some reason, dex-cool is very readily available. It's also remarkably similar to G12: silicate/phosphate free, OAT additives.
    Sep 28 2009
    ky
    Quote Originally Posted by laserb5 View Post
    you would be wrong. you are correct in stating that mixing will cause that, and will accelerate this happening, but this happens as well on its own. im not even going to argue it anymore, if you want to do it, go right ahead. ive seen this many of times with using dexcool/water only.
    Veteran Member Four Rings BlazinB5's Avatar
    Nov 12 2010
    Stillwater, MN
    Quote Originally Posted by bigern45 View Post
    dont use dexcool.
    ever.
    $100 says that coolant wasn't changed every 30,000 - or ever.
    obviously G12 is top of the line, but ANY coolant is going to go to shit if you don't change it as often as you should - and some people virtually never do (until problems pop up)
    2001 Allroad 2.7T
    2000 A6 4.2 (parted out)
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Sep 28 2009
    ky
    Quote Originally Posted by BlazinB5 View Post
    so? whats your point? have you ever seen conventional green do this? honda blue? audi pink? i havent. maybe at 200k+ miles and 12+ years with the green, but those are few and in-between.
    agreed, cooling system was neglected in the pic i showed. was excessive and nasty to make a point and be helpful. ive seen them with regular dealer ship scheduled services, and 60k in, there are signs of the build up.
    Jan 19 2011
    PDX
    Or, you know, instead of hearsay, the several AZ members (including myself) who have run it for thousands of miles without incident. Absolutely no mixing and good cooling system maintenance is much more important than what you run.
    Veteran Member Three Rings omgwtfbbq!'s Avatar
    Jul 08 2009
    Daytona Beach, Fl
    Quote Originally Posted by Taloras View Post
    Instead of hearsay, heres some different hearsay!
    01 Sedan /// Brilliant Black ///F4H Frankenturbos w/ tubular manifolds /// J-Fonz stage 3- /// Borla 3" /// Darintake
    I hate: FMICs, flat colors, A-pillar gauge pods, vented hoods, drilled brake rotors, SSAC products, Rotas, you
    Nov 25 2009
    Spring Lake, MI
    We have trucks that come in with 150+ thousand miles that have had schedualed cooling system flushes and I have never seen that goo in any well maintained vehicle. The only cars that end up looking like that are the ones that the customers don't give a damn about their car and don't do any recommened maintinence. These are the same people that run 5,000 - 7,000 miles on conventional 5w30 oil before they come and get it changed. I'll heed your warning, thats for sure. But, I'm comfident that as long as I follow the recommended flush intervals that I will be fine. And if I do end up ruining anything, I'll have nothing to blame but my imcompitence.
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    Do not mix
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Nov 12 2010
    Stillwater, MN
    Quote Originally Posted by ThunderWuss View Post
    yep.. just run it. i'm actually considering doing it, since i know for a fact that i'll keep up on it and change it every 30,000/3 years.
    edit: why would i do this? there aint a damn place/store around here that sells it. then again, i wonder how much the dealership would charge for it, now that i think of it. does anyone know?
    2001 Allroad 2.7T
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Nov 27 2012
    United States
    German cars are picky at best. I would never use anything but g12 or g12+ it's cheap insurance especially if your just topping off. g12 and dex cool are not the same. I have seen them gel on customer cars. We even did tests in school with prestone/dex cool/g 12 and g12+
    http://www.blauparts.com/proddetail.asp?prod=J4D2000
    thats not bad at all for price and ships very quick.
    Most people I know including me when looking at Audi/VW's for sale look at the color of the coolant..if its green I walk away. Yes you can flush the entire system and use green but most dealers and private sales do not flush the entire system and the two WILL gel over time if the two are mixed.
    Veteran Member Three Rings joe dub's Avatar
    Sep 01 2008
    Illinois
    i used dexcool once for a weekend and my clutch blew
    silver - RIP
    black - TAILS
    Sep 30 2011
    mid ohio
    ^^^LOLOLOL^^^
    Senior Member Three Rings ontheedge56's Avatar
    Sep 13 2011
    01 S4 Avant
    Ithaca, NY
    can I run my car with sand instead of oil?
    Ever need help with your Audi in Ithaca. Hit me up.
    -Dan
    Aug 13 2008
    Indiana
    Quote Originally Posted by ontheedge56 View Post
    I prefer glass bead like they use for sand blasting. They're like mini ball bearings!
    -Nic
    Oct 05 2010
    York PA
    used dexcool in my car for 25k, car had 212k when i sold it, guy rebuilt the motor for stage 3 and had no issues with any sludge anywhere
    Oct 02 2006
    Wadsworth,OH
    If you plan on flushing your coolant why not refill with G13? This is the new industry standard. Check out some information below.
    PDF on flushing your coolant and more info: Click HERE.
    Jason
    Veteran Member Three Rings Jmills's Avatar
    Jun 20 2012
    Jason
    My favorite quote from that installation pdf:
    "There are many cheap testers on the
    market, some costing less than cheesburger."
    '00 Hibiscus Red Pearl B5 S4 203k on stock k03s! MTM Stage 2...273 AWHP 344WTQ - SOLD Sadly
    2006 Tarmac Black Evo IX 325whp 310 wtq - Daily while I figure out the next Audi
    The Other FB group, the SFW English speaking one, 10,000+ Members
