I've tried to get this darn thing working for months now but everytime we connect the can hi/Low we throw multiple error codes and still can't get park assist module 10 to connect. here's a log. any ideas?
Saturday,12,December,2015,10:55:09:48746
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 15.7.2.0
Data version: 20151124
www.Ross-Tech.com
VIN: WAUHFAFL0CA119445 License Plate:
Mileage: 65160km-40488mi Repair Order:
Chassis Type: FL (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
72 77
VIN: WAUHFAFL0CA119445 Mileage: 65160km-40488miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 1010
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 1010
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 1010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: Sporadic communication error 1000
77-Telephone -- Status: OK 0000
Address 01: Engine (0-----CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H20 0002
Revision: E1H20---
Coding: 0104010A180F0160
Shop #: WSC 06208 000 00000
ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002
ROD: EV_ECM20TFS0118K2907115AG.rod
VCID: 74EDE295DF05459E7F-8020
9 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [036] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 3
Mileage: 65169 km
Date: 2015.12.12
Time: 10:37:44
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [036] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Mileage: 65169 km
Date: 2015.12.12
Time: 10:37:44
7135 - Body Control Module (Central Electric)
U0140 00 [036] - No Communications
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Mileage: 65169 km
Date: 2015.12.12
Time: 10:37:40
5558 - Body Control Module (Central Electric 2)
U0141 00 [036] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Mileage: 65169 km
Date: 2015.12.12
Time: 10:37:45
5615 - Door Control Module - Driver's Door
U0199 00 [036] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Mileage: 65169 km
Date: 2015.12.12
Time: 10:37:39
7150 - Please Check DTC Memory of Steering Wheel Electronics
P1698 00 [036] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Mileage: 65169 km
Date: 2015.12.12
Time: 10:44:04
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [036] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Mileage: 65169 km
Date: 2015.12.12
Time: 10:37:39
4720 - Body Control Module (Central Electric 2)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Mileage: 65169 km
Date: 2015.12.12
Time: 10:37:39
7663 - Boost Pressure Control Valve (N249)
P2261 00 [104] - Mechanical Malfunction
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Mileage: 64812 km
Date: 2015.12.05
Time: 15:49:00
Readiness: 0010 0001
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 070D18
Shop #: WSC 06324 000 00000
VCID: 0201B44D9DB17B2E7D-8056
6 Faults Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:39
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x0032
Hex Value: 0x028D
Hex Value: 0x00FF
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:44
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x001C
Hex Value: 0x7A8F
Hex Value: 0x00FF
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:45
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x02A2
Hex Value: 0x0023
Hex Value: 0x628F
Hex Value: 0x00FF
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:51
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x02A2
Hex Value: 0x0026
Hex Value: 0x468F
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:44
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x001C
Hex Value: 0x7A8F
Hex Value: 0x00FF
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:44
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x001C
Hex Value: 0x7A8F
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H05 0435
Revision: 00002001
Coding: 0B0100
Shop #: WSC 06325 000 00000
VCID: 76E9D89DC179578E41-8022
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H60 0072
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H38 0042
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 26
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:30
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01040320120510
Coding: 64002000
VCID: 0005BE4593BD693E6B-8054
2 Faults Found:
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:36
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 63
Time Indication: 0
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000001249463
Coding: 26001015063CAF010000000300003D0D0F1C12080201016100 0000
Shop #: WSC 06325 123 12345
VCID: 3C7D0AB5BFD5CDDE77-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 290212 H07 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
4 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 5
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:00
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:00
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:39:00
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:00
Address 10: Park/Steer Assist
Cannot be reached
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H45 0610
Serial number: 003GLD90E8LJ
Coding: 303837354230303030304A55304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 458B6F51C41F8C1618-8010
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1200004KNZ
Crash sensor for side airbag; driver side:
Serial number: 6334MSME6B223A34E
Crash sensor for side airbag; front passenger side:
Serial number: 6344MSME6B634114A
Crash sensor for side airbag; rear; driver side:
Serial number: 6352QSME770E255EV
Crash sensor for side airbag; rear; passenger side:
Serial number: 6362QSME520D216EL
Crash sensor for front airbag; driver side:
Serial number: 63732SME310F0576-
Crash sensor for front airbag; front passenger side:
Serial number: 63832SME530F3150W
1 Fault Found:
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 63
Mileage: 65169 km
Date: 2015.12.12
Time: 10:37:40
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372LBP000DT
Coding: 000016
VCID: 3D7B07B1A4CFC4D640-8068
Component: E221 - MFL H03 0003
5 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 6
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:38
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 63
Mileage: 65169 km
Time Indication: 0
Date: 2015.12.12
Time: 10:37:38
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 63
Time Indication: 0
Freeze Frame:
Fault Status: 00100101
Fault Priority: 2
Fault Frequency: 2
Reset counter: 63
Time Indication: 0
Freeze Frame:
(no units): 44.0
Text: 2C9CFFFFFFFF00C0FF
Distance: 65535 cm
Raw, Index/Key Err.: 255 255 000
Text: 3E8A0000FFFFFFFFFF
Knock Sensor: 0.000 V
Raw, Index/Key Err.: 255 255 255
