These are US prices. Kufatec in the US seems to take 30+ days, hopefully it's faster to Europe. carsystems.pl also sells kits, you might want to ring them to see what they could provide to fit a B8 module in a B8.5. Here are some notes I had typed up as a start of a DIY (the thought is that this is so involved no one will be interested!):
You can do it two ways - either:
Kufatec kit - 35725-2 - $885
OR:
Kufatec Harnesses & other parts Included in Kit:
36316 – Front sensor harness to rear park distance controller ($56)
39880 – Connect rear park distance controller to rear sensors ($42)
36315 – Central electric harness – button + buzzer + power to rear PDC controller ($42)
36318 – Front bumper sensor harness ($56)
4x 1S0 919 275 Front PDC sensors (eBay) *1
1x 8K0 919 475 AA PDC Module (carsystems.pl) *2
1x 8E0 919 279 Parking Buzzer (for front) (eBay from China $15; dealer/ECS $30)
1x 8K2 959 674 G V10 Button (ESP, Parking) OR 8K2 959 674 J V10 (ESP, Parking, Blind) ~$70
Also needed (unknown if these parts are included in Kufatec kit - I don't think they are):
2x 3C5919491N Left/Right Inner bracket (ECS) *3
2x 3C5919491M Right Outer Bracket (good for both left & right) (ECS) *3
4x 3C0919659 Parking Sensor Washer (ECS)
1x touchup paint for PDC sensors (automotivetouchup.com) *4
1x 8K0907297 PDC module holder (ECS)
Misc odds & ends (ECS):
2x 4L0886373 - rear seat grommet - it's one time use; you need to take the rear seat out (pull up very hard) to run the wiring, this part will get damaged in the process and needs to be replaced
2x 7L6868307 - plastic rivet for parking buzzer
1x 8E0972416 - housing if you have Audi Side Assist - this is needed to modify harness 39880
2x plastic bolt to hold PDC module bracket in (still looking for a part # for this)
*1 - There are many part numbers, these are the same sensors that are used on a ton of German of cars - this is the model I looked for - I got some shipped from Germany for $14 EUR/piece shipped. Other places online have them for $25. From the dealer they're like $100/ea, so I would avoid that!
*2 - I got the PDC module shipped from carsystems.pl for $108EUR. The "AA" at the end is the important part. Search with & without spaces if you have trouble locating Audi parts in a search engine. Dealer/ECS would be around $250.
*3 - these are VW parts - Audi doesn't sell the A4/S4 brackets separate, I am not 100% happy with them but they definitely worked. I chose to use some HomeDepot Plastic Epoxy to glue them on to the bumper after cutting the hole, but I probably would have preferred to use a hot glue gun if I owned one.
*4 - I purchased spray paint & spray clear coat, for about $40 shipped from AutomotiveTouchup.com I did a couple coats of color after sanding the sensor down and a couple coats of clear. You can get your paint code from the PR Code sticker -
http://www.audienthusiasts.com/Articles_PRCodes.html
Tools:
To add power (from driver side fuse block to passenger side fuse block), you need 2 of this Tyco contact: 964324-1 and a length of 20awg / .5 mm2 wire
If you have Audi Side Assist, in addition to 8E0972416 you need Tyco contacts: 10x (+spare) 962886-1 and 10x (+spare) 963715-5 and 22 awg / .35 mm2 wire to modify the Kufatec harness (if you get the same one I got - maybe if you ask them they can provide you the correct harness) to pass through the bumper harness to main wiring harness while diverting parking sensors to the trunk parking module.
