Results 1 to 19 of 19
    Veteran Member Four Rings adamkb26's Avatar
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    Covering up front license plate holes
    Has anyone removed the front plate and used anything to cover the drill holes? I'd really like to get the ugly thing off the car but am not sure what I could use that would look good. Thanks!
    2018 Mythos Black TT RS
    034 Stage 2 ECU/TCU | IE Carbon Intake/Inlet | AWE Switchpatch | Forge Motorsport FMIC | 034 Parts: HFC DP, Dogbone Mount/Inserts, RSB/End Links, Subframe Inserts, DSG Catch Can | Euro OLEDs | AP Carbon Wing/L Blades | HRE FF11
    2018 RS3 | 2018 S5 | 2017 TTS | 2015 RS5 | 2013 S4
    Junior Member Two Rings
    Sep 11 2012
    NorCal / SoCal
    I used a Dremel to clean up the mess created by the self tapping screws. Then Plastidipped the grill.
    Quote Originally Posted by adamkb26 View Post
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    I didnt remove my front plate, but a piece of vinyl works wonders...
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Veteran Member Four Rings thedollardoctor's Avatar
    Oct 28 2012
    Dayton, OH
    Quote Originally Posted by phikiji View Post
    +1, same here! 1,000 times better IMO
    2013 Audi S4 | Ice Silver | DSG | GIAC/AWE Stage II with DSG Tune | Roc Euro Intake | AWE Full Exhaust w/ Resonated DPs | VMR V713 19x9.5 et45 Matte Black | H&R OE Sport Springs | USS Sway Bars and End Links | Alu Kreuz | Color Coded Custom Painted Headlights and Emblems by ONEighty Customs | RS4 Style Honeycomb Grille by ECS
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    Do you have to remove the grill to plastidip it? Don't know much about the process.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Do you have to remove the grill to plasti dip it? Don't know much about the process.
    I believe you can just mask the grille. As I understand it, the plastidip does not actually adhere like paint and it can be peeled of in the future. My question is what do you use to close up the holes before you plastidip the grille?
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    Yeah I was gonna ask how it covers the holes as well.
    Veteran Member Four Rings Moose201's Avatar
    Aug 26 2012
    2013 S4 Ibis 6MT
    Here's another post with pics of plugs that were used to fill the holes: http://www.audizine.com/forum/showth...=Holes+license
    www.coldwartourist.com - Exploring ruins & relics of The Cold War
    Prior: 2006 S2000, 2005 S4, 2004 Mazdaspeed Miata, 1999 M3
    Veteran Member Four Rings kooltechie's Avatar
    Sep 04 2007
    '13 S5, '18 540i, '21 ID.4
    Pasadena, CA
    here's what I did:
    1. bought 4 plastic hole plugs (rivets / fasteners / etc) with 1/8" (3.16mm) hole size from a local parts store
    2. bought a can of gray spray paint (or any color that matches your grille)
    3. on a hard-paper box (i.e. an empty kleenex box), made 4 holes using a nail
    4. pushed each hole plug half way into each hole (so that there's no contact between the head and the box)
    5. applied a coat of paint on the plug heads only
    6. let them dry (overnight)
    7. repeated step 5-6 twice
    8. cleaned the holes on the grille and flattened the edges of them
    9. pushed the plugs into the holes
    Here's the result:
    2013 S5 Glacier White | Black Alcantara | DSG | Sport Diff | MMI Nav + | B&O | Carbon | Advanced Key | 19" Ti Peeler
    APR ECU/TCU | PSS10 | AWE Touring | EC Alu Kreuz/Sways/End Links | SPC MS Edition UCA | VMR V810 Gunmetal 19x9.5 (et25) | Michelin PSS 265/35 | Xpel Ultimate | 3M Crystalline
    Oct 28 2012
    Dayton, OH
    ^^ In my opinion those plugs are UGLY!
    To answer your question, yes, the grille can be plasti-dipped without removing it from the car. There is a DIY on here somewhere of how to do it that way.
    In general, after you dremel the plastic around the holes, the holes are very small. The plasti-dip basically fills in what's left
    Sep 04 2007
    Pasadena, CA
    yup, they're not pretty for sho
    wish my car came without the license plate holder....that would've been the best.
    I've played a bit with plastidip, but didn't like the color as much as the factory grille color - unlike some ppl on AZ, I like how the factory grille looks.
    and most people don't even notice the plugs unless I tell them.
    I personally like the plugs over plastidip
    May 15 2012
    2021 Q3 S-Line
    Indianapolis, IN
    So if I were to plastidip the grill, which products would I need to accomplish it? Do I need the whole pro car kit or would a few cans work?
    Oct 28 2012
    Dayton, OH
    Quote Originally Posted by kooltechie View Post
    Right on man, obviously when it comes to looks its "each to their own", I've just never been a fan of the OEM grille. If you like it, that's all that matters.
    Oct 28 2012
    Dayton, OH
    All you need is 1-2 cans of plasti-dip spray. There are several DIYs on here that will explain all you need to know. You can also hit the link in my signature below and read some thoughts I have on it as well as see pics of the process.
    It's VERY easy to work with overall. PM me if you have any specific questions or concerns. Happy to help!
    Aug 13 2017
    Cincinnati, OH
    This was my solution. $10 for carbon fiber vinyl on Amazon.com. A little trick: use regular masking tap to create a template. Tape over the spot you want to apply vinyl. Then remove the tape and apply to the back of the vinyl. Cut with scissors and you have a perfect match. I also did a little dremel work to the holes and added some bondo from a tube.
    Jun 08 2005
    Lexus RX 350
    SE, PA
    I like it! But if you use matte or gloss black vinyl, it will look almost invisible and you will not see the center area. Just a matter of what you are looking to do.
    Mar 20 2015
    McKinney,TX
    I filled them in with screw covers from home depot
    Apr 26 2017
    2014 Jeep Wrangler, 2014 Acura MDX
    Illinois
    I sanded down the holes until they were smooth then covered with vinyl from GrafiXpressions (http://grfxpstore.com/store/product/885037488). Can't tell there are any holes at all and looks OEM (except that I went with black vinyl instead of gray). It was super easy and took less than 20 minutes.
    2015 Audi Exclusive Nogaro Blue S4
    6MT / Blue Alcantara Interior / Prestige Model
    Modifications: Alu-Optic Trim / Supercharged Badges / Grfxp Matte Black Grille Strips / Viper Charcoal 35% Tint / AWE S-FLO Intake / CR-15 / H&R OE Sport / EC Alu Kreuz
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    Ok, now I have this solved, how about rim rash. I had never curbed a rim in 40 years of driving, and if I haven't fucked up all 4 on this car. There is some jagged concrete on the streets in this town, I always feel good when I don't see a tire blister but my rims get hurt.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
