Results 1 to 15 of 15
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Intercooler pipe sizing question. 2" vs. 2.5" for big turbo
    So I got my intercooler core for my build which has 2.5" outlets both sides. Which one would I benefit more from? flow vs. lag? turbo going in is a 71r Elim.
    Discuss.
    2016 S3
    Instagram- @Thisisastickup
    Senior Member Three Rings Low-n-Slow A4's Avatar
    Jun 11 2011
    Bay Area, California
    I've read threads of the benefit of a 2" hot pipe and 2.5" cold side ( hot side being turbo side of the FMIC and cold side being the throttle body side) being that the air is more dense after the FMIC and smaller hot pipe helps the velocity to get the hot charge cooled faster (into the FMIC). Unfortunately I have not experienced it personally, just read. =\ good luck, sorry if this was no help, haha.
    Oct 27 2010
    Norwood, MA.
    Just trying to decide between a Cxracing piping kit (2.5", $299) or a speedy racer ebay full kit (lolol) which is 2", and a little cheaper. I plan to trash the core and use one ive already got and use some higher quality t-bolt clamps.
    2016 S3
    Jun 11 2011
    Is it the pre bent kit for our car from CX racing? If so then their kit does start as 2" and becomes 2.5" on the cold size. Is $299 what they're charging for their pipes? Seems kind of pricy since their complete FMIC kit is $350-380 shipped. If you were to make your own piping it would be a bit of work and you would need a map sensor flange welded as well as down time on your car, if its your DD
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    I didn't notice much difference going from 2 to 2.5 on that turbo. Does it flow more? Probably but it's hardly measurable and there are alot of other areas you can gain spool and power from first.
    A3 8V | 10.89@129 | Boss700 | Eurodyne
    Oct 27 2010
    Norwood, MA.
    Yeah $299 is what I was quoted when I emailed them. I figure subtracting the core doesnt take much $$ because its about as dense as a soda can? Idk though never seen one in person
    2016 S3
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by 613B6 View Post
    Understandable. Ive just bought the 034 large TIP off the classifieds and the adapter from 034. I have the stock cat and dp to figure out what im gonna do with, I have a borla dp back. Thinking 034 Hfc and tt downpipe? Or is that going to be restrictive?
    2016 S3
    Senior Member Four Rings iHaveBoost?'s Avatar
    Jul 26 2012
    JHM'd B6 S4
    Waltham, MA
    2.5" inlet and outlet, just go with 2.5" piping. 2" is stock isn't it? You'll want something bigger for a 71r.
    I have a friends Racetec intercooler I've been looking for 2.5" piping for, for my 71r installation. What a pain in the ass..
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Larger diameter piping means a slower air velocity.
    2019 SQ5 Prestige
    Veteran Member Four Rings MmmBoost's Avatar
    Nov 29 2005
    10 A4 Avant S-line, 07 Suzuki GSX-R600, '69 VW Beetle w/ 1.9L aircooled turbo
    Edmonton, AB
    for a 71R you'd probably be just fine with 2" hot 2.25" cold or 2.25/2.5.
    I would add a thumbs up for the piping from CX Racing. They use nice thick 2mm wall tubing for their pipes which is much easier to work with when fabricating pipers and it won't crush as easily when tightening clamps.
    ~Chris
    I sold my Audis and bought a Touareg... Catch me over at Club Touareg
    My B6 Avant GT2871R build
    Tumblr
    "Robert Bosch don't fuck around"
    Oct 27 2010
    Norwood, MA.
    Yeah I just got off the phone with CX. Got the piping kit w/ black silicone for $315 shipped across the country. My core from silicone intakes looks to be of nice quality, heavy duty B&P construction, but I bought it thinking it was going to be for a frankenturbo. Dan[fn]6262 said those belong in a kids meal, so I got a 71r. I will be logging to see if this will support the larger turbo, I hope so.
    2016 S3
    Mar 27 2005
    The Cold North
    Quote Originally Posted by b6Hate4 View Post
    You caved into Dans peer pressure. I hope you car isn't on jack stands as much as his was..
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by EBG 18T View Post
    Maybe while Its up on jack stands ill throw in a 3.2 from my dads acura with a blown tranny. PA-POW.
    In all seriousness I hope its (semi) smooth sailing. I can deal with a few speed bumps but not a disaster.
    2016 S3
    Mar 27 2005
    The Cold North
    As long as you have all the parts, a few spare clamps and tools you should be all set. Just take your time and be patient. I have a hard time with the patient part..
    2020 Chevy AEV ZR2
    Oct 27 2010
    Norwood, MA.
    Yeah Im trying to take my time. SINCE IVE OWNED MY CAR ive been stage 0 running 3 psi. Broken wastegate flapper. Thought it really was just that effin slow till i recently got a boost guage. Decided its time to do something about it. my car is going to feel like a rocket hahah
    2016 S3
