Results 1 to 40 of 47
    Senior Member Three Rings usmc.S4's Avatar
    Jun 20 2011
    Emissions with catless exhaust
    Did some searching, didn't find a solid answer. So how do you guys pass emissions without cats? Throw the stock DP's in?
    Veteran Member Four Rings bigdo26's Avatar
    Jul 21 2009
    I'm looking at having my stock main cats welded into my non-resonated mid-pipes (I have catless resonated mid-pipes normally) and just clamp those in & hook up O2's for emissions. Little bit of a pain, but not as bad as putting back in stock DP's.
    Although I need a new O2 sensor first :) I think that is easiest if you have the parts
    2014 Mustang GT w/track pack and Recaros
    Sold: B5 S4
    Track videos: Watkins Glen
    Track videos: Limerock Park
    Jun 20 2011
    So how would I do that? Cut my stock cats off and weld the right size pipe to the ends so I can clamp it to my exhaust?
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    If you ask around, you may be able to find somebody local who can code out your rear O2 sensors.
    I live in PA where to pass emmissions you just can have any CELs and need to set all but 2 monitors (I believe that went up to all but 1 monitor for 2002+my or something).
    I found a guy on here, who I won't name, that was able to code out my rear O2s so that my cat monitors set immediately (I still have my main cats in, just gutted pre-cats, but plan to gut the main cats once I have a reason to take the car apart again...probably when I change my clutch in the next month or so). By gutting the main cats, in place of using test pipes, and leaving the rear O2s in the bungs, my exhaust will appear to have cats intact and O2s reading emmisions
    Veteran Member Three Rings c0rrup's Avatar
    Oct 15 2010
    Fairfield County, CT
    In CT there is no visual inspection, I can pass emissions with no exhaust or downpipes as long as readiness codes pass.
    TiAL 605s | ER Intercoolers | Clutchmasters FX400 | EPL Tuning | ICS Performance
    Jun 20 2011
    Quote Originally Posted by c0rrup View Post
    Good thing I'm from CT, I'm stationed in NC and Ive been exempt from emissions testing because I'm active duty. But I'm getting out soon and will require testing shortly after. So if I get my rear o2's coded out I'll be set? CT doesn't do the sniffer correct? Just the plug in?
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    make friends
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Oct 15 2010
    Quote Originally Posted by usmc.S4 View Post
    They slap in the cable, scan it, and you are on your way. They don't even start the car.
    May 16 2008
    South Texas
    It's likely Your car won't pass a sniff test without cats. It depends on the testing method your state uses. In Texas AWD vehicles and diesels are exempt from emissions testing.
    May 05 2011
    SC
    NC just does a readiness test..They should not be using a sniffer or anything like that. Only via the OBDII port.
    OOOO 'Cause I like to party. OOOO
    Jun 20 2011
    Quote Originally Posted by MadProfessor View Post
    I'm stationed in NC, my car's registered in CT. Don't have to do emissions until I get out of the marines, which is in like 6 months. Just trying to get my car ready for back home so I'll pass. But the main question is, will coding out my rear o2's work?
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    Yes. CT is awesome with emissions, get that "ish" coded out. Go there with your down pipes dragging on the ground and you are fine.
    I can help you with the rear o2 jazz.
    Established Member Two Rings ///BlueS4's Avatar
    Jul 24 2011
    Milwaukee, WI
    I had my cats cut out and pipes welded in and the o2's pushed back a little further then stock placment. I also add a spark plug non-defouler and havent gotten any check engine lights no failed emissions either.
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    Lol @ emissions... so glad I am from Michigan, almost anything is street legal (for michigan law, still federally illegal)
    RIP Daz, you will be missed.
    May 13 2011
    2015 BMW F30
    You guys don't know how good you have it!
    | Autospeed | JHM | Pure MS
    Sep 18 2012
    State College PA
    All depends on where you live.
    Where I live in PA there are no emissions testing. just mechanical testing.
    Makes things very easy ;-)
    If you just need your ecu tune tweaked to set things as ok I could help you out there.
    May 28 2012
    Boston
    Cant you just get defoulers and space the o2 sensor a bit off the exhaust??
    Apr 18 2007
    ny
    Thank God New York doesn't use the sniffer anymore, not that I would run without cats or SAI on public roads
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Jul 21 2009
    I coded out my EGT's and rear O2's, so I don't have any CELs, but will readiness codes be OK? I read up a while back on those, but don't recall details
    Sold: B5 S4
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    Quote Originally Posted by bigdo26 View Post
    Depends on how you did it.
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    Yea depends how u did it. Seems like these days u can't completely delete rear o2. U need to have the o2 heaters on since the new emissions computers test for them.
    Basically either run o2 spacers or code out the catalyst efficiency code and leave all the others
    /thread
    Jun 20 2011
    Quote Originally Posted by Dr. Funk View Post
    No cats
    Nov 16 2006
    Boston
    So what? The spacers take care of the no cat issue. I'm amazed how few people bother to do research and just ask here wanting people to spoon feed the info, then when someone spoon feeds it, they spit it up
    The rear o2 just need to measure a diff o2 value than the primaries. This way it thinks the o2 car is working. Spacing the o2 achieves this effect
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Jun 20 2011
    Quote Originally Posted by DxC View Post
    Ok...I took what he said as put spark plug defoulers in my cats, so replied that I don't have any cats. And I'm so sorry I didn't do enough research for you, I'm an active duty Marine, I'm pretty busy most of the day. All I asked was how people pass emmissions without cats. but since you seem to have another answer, where do I put my secondary o2 sensors if I don't have cats?
    Veteran Member Four Rings phila_dot's Avatar
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    /thread
    You can completely delete the rear O2's with a proper codeout. The emissions computer only knows what the ECU tells it.
    IMO, O2 codeout is the only solution. Defoulers can cause other issues.
    The only thing to worry about when running catless is the sniffer if your state requires it.
    Jun 20 2011
    Would I pass with a Jfonz tune with rear o2 codeout?
    Aug 30 2007
    nyc
    spark plug defoulers or similiar are used as spacers to to space the rear o2 sensors out a couplue of mm from the exhaust stream so it thinks the air is still clean and the cat is doing its job.
    c5 A6 tip
    this n that
    Veteran Member Four Rings jolio1994's Avatar
    Sep 06 2011
    Little Egg Harbor, NJ
    I heard it's possible to pass with e85? Is this true?
    Jun 20 2011
    Quote Originally Posted by dannyn424 View Post
    Again, no cats. Where am I supposed to put defoulers? Weld them into the test pipes? I'd rather have the rear o2's coded out. Does anyone know if jfonz's tunes with o2 codeout pass emissions?
    Nov 16 2006
    Boston
    Quote Originally Posted by phila_dot View Post
    Hehe maybe that flies in your state but not in ma and ri now. They purposely reset the heaters or
    Something in the test and it should go to not ready- and if it doesn't it red flags
    Yea easiest is to code out rear o2 if you can where you are.
    Anyway yea throw in rear o2s where ever you want
    1999 Black A4 Avant
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    Of course, everything resets thats supposed to when it's done correctly. It works in every state.
    I know a little bit about this subject.
    The sniffer is a little bit tougher.
    Jul 21 2009
    I think I have 'completely' coded out my rear O2's using TunerPro to modify the bin file per the S4 tuning wiki... any other parameters aside from the below that are needed? I haven't worked on tuning in about a year, so I'm a little rusty
    Set these to zero to disable rear cat DTC:
    CDKAT - Cat diagnosis in OBDII-Mode.
    CWDLSAHK (0x18663) - Code word for probe aging after KAT[31]
    If you want to remove your rear O2s entirely, also set these to zero:[32]
    CDHSH - Post cat O2 heater diagnosis
    CDHSHE - Post cat O2 heater amplifier diagnosis
    CDLATV - Lambda sensor aging diagnosis (tv) in OBDII-Mode (inverse: EURO-Mode)
    CDLASH - Lambda sensor aging diagnosis (SHK) in OBDII-Mode (inverse: EURO-Mode)
    CDLSH - Post cat O2 sensor diagnosis
    CDLSHV - Lambda sensor sensor interchange recognition
    Sold: B5 S4
    Oct 14 2012
    Upstate NY
    Check the s4 wiki now. There have been a few changes, apparently there is no need to change the error classes, and two additional parameters have been added (esknof).
    Jul 21 2009
    I'll take a closer look at s4 wiki and read up!
    Sold: B5 S4
    May 28 2012
    Boston
    just use the 02 spacers.. weld them in to your test pipes in the event something happens you can swap the test pipes out.. trust me, DXC is right about coding out the rear o2s.. it use to be a simple thing but now you run the risk of getting flagged.. in MA they require you to go back to stock if you get caught. once the spacing is set with your mods you are solid as a rock.
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    If it is done correctly it cannot be detected. There are bits that identify the hardware that is tested/supported, as long as these aren't disturbed then you won't have any problems.
    Oct 14 2012
    Upstate NY
    I think he's saying that they reset readiness, and if it doesn't go to failed/not completed (stays ready), they fail you.
    May 26 2010
    2001 S4, 2019 Q5
    Philadelphia
    Quote Originally Posted by ddillenger View Post
    And I'm saying that if it's done correctly then it resets just like it should and readiness sets again after the required driving cycles.
    May 13 2011
    2015 BMW F30
    This. phila-dot knows a thing or two about tuning.
    Oct 14 2012
    Upstate NY
    I wasn't arguing with him. Just asking him to clarify.
