While I was attempting to clean my battery posts/terminals which had become corroded I loosened the actual battery post. The cable was so stuck that when I was twisting the cable, the actual battery post was moving with it and it came up just a little (literally 3-5mm if that). I was finally able to get the cable off the battery without the post moving any more. My question is, a) will this affect the battery in any way? b) is there a way put the post back in its original position? and c) can I still try to clean it with a baking soda/water mix? This happened on the negative terminal.
Here's a picture of what happened
http://flic.kr/p/dKgDBK
