Results 1 to 18 of 18
    Senior Member Two Rings jamezz23's Avatar
    Feb 28 2012
    07 A4 6sp manual
    Michigan
    Exhaust smell coming through vents at idle.
    When I have my heat on and idling at a traffic light I get an exhaust smell coming from my vents so bad that I have to shut it off until I get moving again. I have no exhaust leak because I just got one fixed and they checked everything. In the summer this isn't an issue with the a/c. Still puts out heat at idle and functions perfectly. And to kill 2 birds with one stone when I direct my heat to 2 areas like vents and feet it doesn't put any heat out at all, just wondering if you have an idea for that also.
    Thanks
    Veteran Member Four Rings CoreyRS's Avatar
    Aug 07 2009
    Ca
    Cabin filter
    Established Member Three Rings CHARLES A4's Avatar
    Jan 31 2012
    Turbo integra 521hp
    queens ny
    I have somewhat the same problem but I get like a burnt candle smell
    BRAND NEW Michelin pilot sport a/s plus 245/35/19
    http://www.audizine.com/classifieds/...35-2f19&cat=48
    Veteran Member Four Rings victimdumper's Avatar
    Dec 20 2011
    Boston / South Shore
    me too.
    oh wait that's the delicious smell of my test pipe.
    2005.5 B7 A4 Avant
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    Re: Exhaust smell coming through vents at idle.
    Might want to check the valve cover gasket.
    Sent from a UHF transmission using Tapatalk 2
    Daniel J
    @gtg_drives
    Feb 28 2012
    07 A4 6sp manual
    Michigan
    I'll check my cabin filter and for leaky valve cover, although I'm not loosing any oil at all I'll still give it a look
    Account Terminated Two Rings
    Jan 05 2013
    Kent
    Dec 25 2004
    Earth
    There are 2 hidden vents(4B0819181B) back by the rear bumper.
    When the wind is blowing up the tail pipe, exhaust fumes can enter the cabin.
    Feb 28 2012
    07 A4 6sp manual
    Michigan
    Okay this is more than a normal smell I'd say, haven't got around to look anything yet, hopefully today sometime
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    i have similar problem, only my car stinks when i crack windows open and go heave on the gas pedal... i changed valve cover gasket, i checked for exhaust leaks twice, i got whole turbo-back exhaust system - smell still exists... my veerdict is, no cat = stinky.
    Jan 07 2013
    Tampa
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    I have the burnt smell as well.
    Kinda smells like someone is using their wood burning fireplace and you walk by there house.
    I have a few things to look at in the spring that I know are issues I have.
    These may be the cause of the smell.
    -I have a coolant leak at my rear coolant flange. Its coolant is sticking to the tranny.
    It gels up before it even hits the ground. Its a very small leak.
    -Valve cover gasket.
    Last time I changed the plugs I noticed oil in the plug holes.
    Im hoping fixing these solves the smell problem.
    Senior Member Two Rings MaRsTaInAgE's Avatar
    Sep 18 2006
    08 Audi Q7 S line Black
    Normal, Illinois
    Funny, I was gonna post this....same thing. Test pipe, Dp, thought I was leaking gas somewhere, guess it's pretty normal.
    Dec 18 2011
    Colorado Springs
    mine does it too..........Test piped....Stock Tune....Altitude + shitty 91 oct gas = smelly car....its an Audi thing...
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Forum Moderator Four Rings docurley's Avatar
    UK London
    Yep I get it too
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Jun 26 2011
    ottawa
    and here i thought i was the only one getting that burnt candle smell My high flow cat was new less then a year ago and i noticed on the top of it, seem like something has been dripping on it so i guess the culprit would be the valve cover gasket. Whats a vc job cost by chance?
    Oct 21 2012
    United States
    Most likely the smell is coming from leaking oil from the valve cover gasket or cam chain seal & half moon seal. Change both and that should solve your issues.
    Oct 21 2012
    United States
    valve cover gasket and cam chain seal / Half moon seal jobs go hand in hand. Both are easy jobs to complete and are pretty straight forward for DIY'ers.
