Results 1 to 15 of 15
    Jul 07 2011
    Phoenix, AZ
    2002 S4 been sitting for 5 years.
    Hey there, I'm new here ( just using a buddies account ).
    I came upon a b5 s4 that's literally been sitting for 5 years. I'm waiting for the title right now.
    Just wondering what pre cautions I should take before starting this thing up ( obviously drain gas, oil, brake, ps, coolant fluid ). Also I know it's a long shot but does the tank have a drain plug? I've heard some cars have a very small one, if not have any of you dropped an s4 tank before?
    since it's been sitting for 5+ years I'm sure either the motor has an issue and or one or both of the turbos. If not all I have to do is what I stated about, rims ( has 3 different rims on it lol ), and a driver side door panel.
    Before anyone one asks I did call the mvd, they told me there has been NO update since 2007 (no liens and not stolen). So I'm just doing the abandoned title process.
    Thanks in advance for any tips/knowledge/input!
    Jul 07 2011
    Phoenix, AZ
    Ah shit, mod/admin please move this to s4 section. Thanks!
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    Not sure about the process of dropping the gas tank but its probably a good idea to drain and get new oil like you said...but....pull the fuel pump fuse and prime the motor with fresh oil before even starting it.
    Jan 11 2007
    Salt Lake City, Utah
    Change the air filter, plugs. Before you put the new plugs in, squirt some marvel mystery oil into each of the cylinders and let it sit for a while. If you want to be extra safe, turn the motor over by hand a few times (24mm 12point socket on the crank bolt on the front of the engine).Unscrew the gas feed line on the fuel rail, put it into a gas jug and use VAG-COM to activate the fuel pump to pump all of the old fuel out of the gas tank. Probably want to replace the fuel filter after that as well, and fill it up with good gas. Make sure there is enough oil in the crankcase (if you are really concerned about the quality of the engine oil, change it now, otherwise change it just after getting it hot for the first time so that all of the crap gets suspended in the oil and drained) . Pull fuse #28 (fuel pump fuse) and crank the car a few times to get some oils to the turbos and to the heads. Start the car to get the oil hot and cycling, then turn it off and change the oil and oil filter with fresh. You'll want to flush the brake lines as well, as the hydraulic brake fluid is hygroscopic and should be changed every 2-3 years, regardless of mileage.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Jul 07 2011
    Phoenix, AZ
    Quote Originally Posted by jibberjive View Post
    Change the air filter, plugs. Before you put the new plugs in, squirt some marvel mystery oil into each of the cylinders and let it sit for a while. If you want to be extra safe, turn the motor over by hand a few times (24mm 12point socket on the crank bolt on the front of the engine).Unscrew the gas feed line on the fuel rail, put it into a gas jug and use VAG-COM to activate the fuel pump to pump all of the old fuel out of the gas tank. Probably want to replace the fuel filter after that as well, and fill it up with good gas. Make sure there is enough oil in the crankcase. Pull fuse #28 (fuel pump fuse) and crank the car a few times to get some oils to the turbos and to the heads. Start the car to get the oil hot and cycling, then turn it off and change the oil and oil filter with fresh. You'll want to flush the brake lines as well, as the hydraulic brake fluid is hygroscopic and should be changed every 2-3 years, regardless of mileage.
    Awesome post man thanks!
    Anyone have experience pulling this motor? I watched the audi video ( old as hell with the blue s4 ) pulling the motor, and with a lift and a friend it doesn't look too hard.
    Veteran Member Four Rings topquarkpc's Avatar
    Aug 03 2009
    PNW
    ok...now...that's a thorough run through... i'd listen to jibber...
    '01 Imola Yellow Avant Sport Package 6-Speed (stage 3 w/Frankenturbo F4H)
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Quote Originally Posted by jakellama123 View Post
    I just did it my first time. also my first ever motor pull. It was easy. The video helped a bit but I pulled mine with my trans as I was also replacing my clutch/flywheel. since the car has been sitting so long what's the mileage on it lie? Was it in garage or what?
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Jul 07 2011
    Phoenix, AZ
    107k, yeah a parking garage.
    Did you use a lift? Or just a cherry picker and stands?
    Veteran Member Four Rings 1gcrazy's Avatar
    Sep 01 2011
    Colorado Springs
    Cherry picker and stands here. Wasn't too bad but I forgot to disconnect the passenger side ground and took me FOREVER to figure It out. First time pulling this particular motor only skimming over the tutorials took me about 5 hours. It was a little different for me though. At first I pulled the head because all symptoms pointed to a head gasket so...
    I'd change the oil prior to starting it. Prime the hell of it though. Replace all fluids an filters ASAP.
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    Quote Originally Posted by 1gcrazy View Post
    I pulled mine the same way. I think I also forgot to disconnect the ground lol. All in all it wasnt bad for a first time (I say this while i still need to hook up all electrical but we shall see soon).
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    you try to spin the motor by hand yet? cars that sit that long tend to lock up.. usually you can break them loose by hand.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Oct 13 2010
    colorado
    pictures.
    17 Audi RS3(catalunya red): midpipes, hr lowering springs, 18x9.5 te37s, 034 front rotors
    01.5 Audi S4 2.7tt 6-Sp (Imola Yellow): Bagged, ko4s, recaro spg, AP rollbar, other bits
    Instagram: nerdiest_
    <<Flickr>>
    Established Member Two Rings scottyboyx845's Avatar
    Aug 02 2012
    Quote Originally Posted by SomeDayAS4 View Post
    pictures.
    +1!!
    EPL Stage 1
    Jul 07 2011
    Phoenix, AZ
    Can you post me all the links/vids please?
    Also I will post pics when there is a door panel and the right rims. haha
    Account Terminated Two Rings
    Jan 05 2013
    Kent
