Hi I have an 02 B6 A4 and I am replacing my valve cover gasket following the DIY on A4mods.com , and when I pulled the injectors, after I released the pressure, I saw the holes where my spark plugs are plugged in filled with something. At first I thought it was oil, and maybe it is a little but I believe the consistency is mostly fuel, because when i checked with a cloth it was clear. I did my spark plugs and valve cover gasket a few weeks ago, and when i did my valve cover gasket alot of oil was in the spark plug area when removing the spark plugs also. I'm wondering if this could be related, or not, or if this is normal? If its not normal are there any common problems in this area? On a side note I do have a good amount of vacuum lines revoved as well if maybe this could have contributed, though I cant see how, but I'm kind of a noob at this stuff for now. Thank you in advance, ill continue changing my intake manifold gasket while waiting so hopefully thats ok. Happy New Year!
