    Active Member One Ring Shibby's Avatar
    Jan 01 2013
    Springfield, MO
    Traction control/ABS/E-Brake lights on/flashing
    I just bought a used '04 Audi A4 Quattro (Wagon) with 130k miles. Since I've had had an issue with my traction control, and ABS light coming on, and so does the e-brake light.. except that one will flash. The thing that is weird is that it only happens after I turn on my headlights. If I try to drive when all of those lights are on, it goes into a limp mode and drives like crap. Turning off the headlights and turning them back on doesn't fix the problem. To fix it, all I have to do is turn it off, and cycle the key 1 or 2 times, and then it's fine the warning lights go off. It does this a couple times a week.. it doesn't matter if it's cold or hot. It just happens at random. I've tried searching, but I can't find anything that matches this exact problem. Any help on this would be greatly appreciated! Thank you!
    Senior Member Three Rings westie180's Avatar
    Mar 01 2011
    Indy
    Is a HID kit in the car? If so, throw it in the garbage and get a kit that isn't awful, or else halogens. You're experiencing issues with electromagnetic radiation.
    Dec 15 2011
    Edmonton Alberta
    Does the car have an HID conversion on it? Sometimes the ballasts on aftermarket HID's can interfere with various modules causing concerns... the ABS computer being very sensitive to interference from them!
    -Richard-
    2009 Rabbit. 1961 VW Beetle Canadian Std. 2012 Ram 1500.
    Darsh Import/Dubsport Inc... My very own VW/Audi parts and service shop
    Certified VW/Audi Tech 20 years +
    Rest in Peace Four Rings EURO_DOLL's Avatar
    Jul 22 2011
    Long Island, NY
    Yeah it's definitely caused from a HID kit. I dealt with this for months when I installed my first set of HID headlight ballasts. Initially, I bought a set of cheap ballasts for my headlights, and they were blowing out every other week. Within a month and a half, I had replaced 9 ballasts.
    It doesn't actually affect anything in regards to the lights showing up (your car is totally fine if that's what the cause is). I recently swapped out my cheaper HID ballasts for canbus ones, and the problem has gone away. It has something to do with improper shielding on the actual ballasts, and it interferes when the ballasts are mounted too close to those modules.
    Get a better set of ballasts if you want to keep the HID's. Or try mounting them in a different spot.
    BOOBS& BOOST
    Current: Bagged 04 B6 A4 1.8T | Bagged 2017 MK7 Golf R
    Past: 03 B6 A4 3.0 Quattro
    Bagged 02 B6 A4 1.8T FWD
    14 MK6 Jetta
    Static 94 Corrado SLC
    15 Golf TDI
    Instagram: @boobsandboost
    Jul 04 2015
    NJ, USA
    This is happening to my 03 a6 but mine has factory xenon.
