Results 1 to 17 of 17
    Nov 22 2012
    Caguas PR
    Question Adding shift paddles
    Hi,
    I have a Premium - so it comes with the standard wheel without the shift paddles and want to know if it is possible to add the shift paddles to the steering wheels without changing the wheel itself. I am aware that probably some Vag-Com has to be done.
    Thanks in advance,
    Daniel
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    Oct 27 2009
    Miami, FL | Boone, NC
    You need to change the wheel.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Nov 22 2012
    Caguas PR
    will have to wait for the $ then. I was asking because I saw this http://www.ebay.com/itm/Steering-whe...f80c8a&vxp=mtr and thougth that probably was an easy DYI.
    Active Member Two Rings veki's Avatar
    Dec 21 2012
    Croatia
    What if I don't have paddle shifting on my car serial, and I want to install it. What I need to do ? Anyone installed ?
    Veteran Member Three Rings Fburg A4's Avatar
    Oct 06 2012
    Fredericksburg, VA
    If you could find some shift paddles to fit your current steering wheel, it could be done. The Tiptronic up/down shift (F189) on the gear selector (J587) sends a signal to the transmission (figure it is a ground signal, maybe a voltage one though, wouldn't be hard to figure out). Just add some paddles to the steering wheel and splice them into the tip shift circuits. Unless there is something I'm missing, all you'd need is 2 switches (or cool looking paddles functioning as switches) and perform some wiring.
    Oct 27 2009
    Quote Originally Posted by veki View Post
    You need a wheel with paddles and a compatible airbag. Most paddle wheels are three spoke. If you have a four spoke wheel, you would need a new three spoke airbag. (The four spoke wheel and the three spoke wheel use unique/incompatible airbags). I got a rare four spoke wheel with paddles, so I didn't need to buy a new airbag. Once you have the wheel installed, you need to tell the steering module that your car has paddles using vag com (easy coding change).
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Active Member Four Rings Rodmar's Avatar
    Jan 29 2012
    None
    Minneapolis, MN
    Just buy my flat bottom wheel with paddle shifters and silver stitching
    BB DTM B7 A4SOLD
    2015 Daytona Gray S4-Black with black Alacantra, B&O, Technology package, Carbon Atlas Inlays, RSD
    Parts on the car: AG M310 18", RS4 Grille, R8 oil Cap, roc euro intake, H&R Street Performance Coilovers, and awe exhaust with res. DP's
    Also in stable:
    2014 VW TDI SEL Passat
    Soon to be in stable:
    http://www.ebay.com/itm/Audi-RS4-Bas...178&rmvSB=true
    Dec 21 2012
    Croatia
    I know that I must buy a steering wheel with airbag and paddles. Problem is electronics. Wiring, coding.. Some diy would bi nice.
    Oct 27 2009
    Unless you get an airbag from a different model, it should be plug and play. Coding is about as simple as could be.
    Steering wheel removal DIY: http://audienthusiasts.com/ProjectSteeringSwap.html
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Dec 21 2012
    Croatia
    I know that all, but thanks anyway.
    Problem is how to connect paddle shifters and activate them. Do I need some extra wires and jacks ?
    Oct 27 2009
    Re: Adding shift paddles
    No, the paddles are wired into the multifunction controls which come with every wheel. Paddle wheels have multifunction controls that wired with the paddles.
    Sent from my Galaxy Nexus using Tapatalk 2
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Dec 21 2012
    Croatia
    That means no extra wires ? Even not from car to the wheel ? Niice !! Now I really think about this mod, beacuse it's a much easier to find flat bottom wheel with paddles. Thanks !
    Oct 27 2009
    Yes, you don't have to do any wiring if you get a compatible B8 airbag. If you get a flat bottom wheel, the airbag harness may need to be modified. Alex at Europrice modifies the harness to fit your car for you if you order from him.
    Take my retrofit as an example. I pulled my airbag and disconnected its harness from the steering column and from the multifunction controls. Installed my new four spoke paddle wheel, connected the multifunction controls to the airbag harness, and connected the harness back to the steering column. I then did the vag com coding change. That's it.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Dec 21 2012
    Croatia
    Ok. Thank you very much for this !
    Nov 22 2012
    Caguas PR
    I wonder 2 things:
    1) Can the paddles be attached physically? Does themounting holes/base are there?
    2) Does the cables and modules are present on the steeringwheel?
    Oct 27 2009
    Quote Originally Posted by Ezmendriz View Post
    I wonder 2 things:
    1) No, it is uninterrupted smooth leather where the paddles would be.
    2) No, the multifunction controls on my non-paddle wheel did not have the extra connectors for the paddles.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
