Last night I was coming home and after about a 40 min ride I got into my home town. Out of nowhere my idle gets really sloppy, I start backfiring like crazy and at one point the car even died while idling. I can't accelerate normally anything over I'd say 10% throttle causes the car to buck/misfire as if it has antilag. No CEL but I got the following codes:
Trouble code 2 ; P0219 Engine Overspeed Condition
Trouble code 3 ; P1292 Map Controlled Engine Cooling Thermostat -F265- Open circuit
Trouble code 1 was system low voltage which I'm going to chalk up to the car stalling. I haven't done any changes to the car recently. We had heavy rain yesterday but everything that should be sealed is as far as I know, including the ECU tray. I also got gas before heading out on the trip but I figure if it was bad gas the issue should've started sooner than that. Looking around at thermostat threads it seems a common symptom is a car that takes a while to warm up. My mother has a B6 as well and I've noticed that hers warms up significantly faster than mine for a while now. Did the thermostat die or is it something else? Any other tests I can run to check?
