Results 1 to 29 of 29
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    LPFP (in-tank fuel pump) failure info
    I found this video posted by Ross-Tech as a confirmation that the LPFP duty cycle should be below 70% at idle with a warmed up engine. So basically everything above 70% should raise questions.
    Here is the info attached to the video:
    "MVB 103.1 is the low side fuel pressure coming from the lift pump in the fuel tank. MVB 106.2 is the duty cycle the lift pump is being operated at to maintain the correct low side fuel pressure. MVB 106.2 should be below 70% at idle with engine up to temp.
    When I pinch off the fuel supply line, my fuel pressure drops down and the ECM ramps up the duty cycle for the lift pump to try and maintain pressure. I did flag the P310B/012555 because of this.
    We see the P310B/012555 issue on higher mileage vehicles. I would suggest to inspect the fuel line to make sure there are no kinks or restrictions, if good, then replace the fuel filter and recheck your values. If the readings are still out of spec, then you could have a failing lift pump in the fuel tank."
    - Chip
    K0R-GT -- S3 injectors -- Maestro tune -- IE Drop-in rods
    "It took 4 bad crankshaft seals and lots of cursing to build my avatar"
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    wow very nice info! good find
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    Ya I was wondering about his. Cause with the dw301 installed in johns car we were still readi above 70% but I think on the aftermarket pump it has a higher duty cycle. Are stock pumps for sure should be below 70%. Seems like above that at idle and people have issues.
    Thanks for the great info shiro! Now get that car runnin right and dyno the sucker.
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Jul 26 2009
    DMV Area
    That's weird. I thought having a higher flow pump should bring the duty cycle down. ^this pump flows more than oem, right? What low pressure are you reading at idle with the new pump?
    - Chip
    Aug 05 2011
    CO
    Quote Originally Posted by shiro1745 View Post
    Ya I thought the same thing too. Oh ya it flows way more than stock. AT idle it was reading 5Bar. Granted we did clear all fuel trim logs and readapted it to stock fuel mapping. Gonna give it one or two days then vag it again and see what it looks like. What we saw was 74% duty cycle at idle with 5 bar pressure after adaption to stock maps and only like 2 hrs after installation.
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Jul 26 2009
    DMV Area
    Than doesn't make much sense
    - Chip
    Aug 05 2011
    CO
    Ya I know. Lol. Waiting to vag it again and see what's up
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Re: LPFP (in-tank fuel pump) failure info
    Goddamn it Tammy! Eat a dick!
    Sent from my porcelain throne.
    2021 Audi S4, P34 Intake
    Dec 03 2008
    2018 SQ5
    It doesn't make much sense. Lol. But the verdict is in. This completely, 100%, improved performance across the board. I have all lost boost back, power delivery is more linear, power comes on harder, faster, low speed/rpm driving is much smoother, rev matching down shifts are smoother. I can hit 23-24 psi in every gear now, where before, I was lucky to hit 20, and 18-19 was more common. The all or nothing gas pedal is gone, and I now have mid range. Also, before, when I was at half throttle in the higher rpms, and went wot, nothing else happened. Now I have acceleration there when I do the same. Overall very happy.
    Aug 05 2011
    CO
    Jim good to hear everything is going good so far. Let me know when you wanna take logs and check the pump out on vagcom
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by seal66 View Post
    Yeah, I'm thinking Monday if you've got time?
    Oct 14 2009
    Okinawa Japan
    Awesome news
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Aug 05 2011
    CO
    Yep monday is cool with me
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Veteran Member Four Rings slvrb7's Avatar
    Dec 28 2011
    2016 Polaris RZR 1000, 2016 Jeep Wrangler JKU, 2017 Range Rover, 2018 Land Rover Discovery
    North Texas
    I'll see you guys Monday... Jk wish I could drive out that way.
    Kris
    Aug 05 2011
    CO
    Quote Originally Posted by slvrb7 View Post
    Do it. It only takes what 15hrs lol
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Time for some hpfp upgrade and meth, what else can you possibly add without going stage 3? you're like $800 bucks until you tap out your car and need a new turbo/rods
    Aug 05 2011
    CO
    I should throw my HPFP in for some fun. But, still waiting on my intercooler to get back from the powder coater. I really need to install my meth kit
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    You have a bmp too don't you? We should install them together, I have no clue where to even begin lol
    Aug 05 2011
    CO
    Ya I bought the bmp+ kit which included the W/M kit
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Dec 03 2008
    2018 SQ5
    Yeah, hpfp will be my next mod if ever I can afford it. Then meth. Then I'm done.
    Jul 26 2009
    DMV Area
    "Then I'm done" hahaha
    - Chip
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Holy thread revival so were you getting fuel cuts as well?
    Sent from my G3313 using Audizine mobile app
    Ivan
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by dalmation53 View Post
    I'm having a really hard time recalling the context of my post. Lol. I did have some fuel cut issues, but after going through 3 lpfps, came to the conclusion there was dirt/ sediment in my fuel tank that was burning up fuel pumps. Had the tank cleaned out and solved my problems.
    Sent from my SM-G965U using Tapatalk
    Aug 19 2013
    Miami
    I'm asking because my car is having fuel cuts as well and have a code for the low pressure fuel pump and needed to know symptoms before k throw a new one in there.
    Ivan
    Dec 03 2008
    2018 SQ5
    Iirc, I was having power hiccups under full load, peak boost, full throttle situations.
    Aug 19 2013
    Miami
    Yessssss sameee here man. Driving normally is fine but i'm having what your saying. I will just replace thr lpfp and see whats up. After yoi replaced yours it was fine after?
    Ivan
    Dec 03 2008
    2018 SQ5
    Like I said, I sent through 3 lpfps before finding the cause of the problem. I think mine was a rare case though.
    Veteran Member Three Rings K1196A's Avatar
    Feb 16 2007
    B9 S4, 2018 Q5, 2012 Tacoma TRD Sport
    DOVER, PA
    Had the same issue. did the pump and filter. no problems since.
    Aug 19 2013
    Miami
    Fixed my problem. It was LPFP
    Ivan
