It's been a long day of heavy snow/rain mix leaving pile of slush everywhere. Got in the car and the drivers floors is full of water, looks to be coming in from the left corner. Pass side is all dry.
checked sunroof drains, they work. checked drain under battery, its not clogged, and the area under the cowel does not appear to have been full of water. pulled cover off ECU, it looks dry in there as well (though it is pretty tight and hard to see, but was all dry) the rear right screw tab was broken, but still dry inside.
poured water along the side of ecu box (between box and fender) and i can hear the water trickle on the ground, but also found a few traces of water droplets inside the car on dead panel when i poured the water. so i think i have narowed down the location. but where exactly? its somewhere around the ecu box or driver side of the ecu box.
the black panel inside the car below dash with the obd2 plug is all wet on the top side. where is this leak?
how do i pull the carpet back so that i can check the floor boards for water and suck the water out? how do i get the side plastic trim panel off so i can pull the carpet?
thanks
im searching but cant find this answer
