Results 1 to 12 of 12
    Aug 03 2009
    Central California
    Lightbulb Audi TT 5x100 conversion to 5x112, no adapters
    Here's the story.... I've googled and checked Audi World, VAG, what am I missing....
    I WANT to convert (newbie here) from 5x100 to 5x112 without adapters.
    I currently have a A4 B6 and just inherited an 01 TT 180.
    Both are Quattro
    I have two sets of extra rims and don't want to add anymore in my garage.
    So.... I've been trying to search for hub and rotors that would do this..... so i can swap rims with my A4 and TT.
    Has anyone successfully done this? because I sure have not found anything...
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    why not just sell/trade a set for TT wheels?
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    Quote Originally Posted by yung turbo View Post
    Yep^ unless you don't want to bother with exchanging, this is your solution: http://store.42draftdesigns.com/VWAu...Set_p_434.html ..Either way.. you will need "something"
    Aug 03 2009
    Central California
    @ Yung .... Don't want to sell a set because one set is my winter.... the other set is my spare I use when roads are hella dry (summer tires) then I have my road trip tires....
    @ AWD ... I saw them... and that's really my last resort.... I really want to swap out the HUBs if that's all i have to do (plus get rotors) but I don't want to take it of the B6 and find out it doesnt work. The only thing I scared of happening is taking a turn too fast that the adapter breaks and my wheel goes one way while the TT goes flipping... Have you used them and if so for how long?
    Dec 18 2005
    nevada
    Quote Originally Posted by irieblues View Post
    Once it's on there, you should be good unless you are Rallying the car... Of course I have no real world experience as I have never used them since I just purchase wheels with the corresponding ET/bolt pattern... But like you said, you already have them and don't want to give them up, so I understand your dilemma.
    Aug 03 2009
    Central California
    I'm just surprised, after 11 years..... no conversion..... or I guess not a lot of peeps want to convert.... or they go the adapter way.
    Dec 18 2005
    nevada
    Did you think about redrilling your 5x100 hubs to 5x112?
    Aug 03 2009
    Central California
    That was an option..... then I would have to redrill the rotors too or just find the right spec rotors and slip them on and I'm set.... I'm always weary doing stuff like this..... I'd rather have them already made as 5x112 then poking new holes.....
    Dec 18 2005
    nevada
    Rotors would HAVE to be the correct size.
    Dec 15 2009
    North Dallas suburb
    Quote Originally Posted by awdjunkies View Post
    This ^^^ (adaptors) is the simple/best solution and is what most (99.99999999999%, but I may not be exact) do because it is the simple/cheap solution. You can make it more difficult and try to swap hubs/rotors, but cost would be greater and result would only be equal at best. No need to reinvent the wheel on this mod.
    Just my 2cents.
    cheers.
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    Check with Adaptec Speedware. I know they do the Double Up system where they sell dual drilled rotors and hubs for 4x100 and 5x100. Maybe they can do it for 5x100 and 112.
    Aug 03 2009
    Central California
    Thanks Chris.... Ended up going with Adaptec... and did the Adapters.... as my research thus far has proven no actual conversion of HUB and Rotor.... Thanks... I'll be getting them just after XMAS.... nice peeps and helpfuly over there at Adaptec!
