Results 1 to 27 of 27
    Senior Member Two Rings jamaicanmecrazy's Avatar
    Feb 05 2010
    Longmont Co
    cant remove coolant sensor
    cant remove the old coolant temp sensor and its driving me nuts ...i removed the clip and its not budging ..i dont want to f this up does anyone have tips
    Veteran Member Three Rings omgwtfbbq!'s Avatar
    Jul 08 2009
    Daytona Beach, Fl
    Did you remove the entire clip or did it shatter like mine did?
    01 Sedan /// Brilliant Black ///F4H Frankenturbos w/ tubular manifolds /// J-Fonz stage 3- /// Borla 3" /// Darintake
    I hate: FMICs, flat colors, A-pillar gauge pods, vented hoods, drilled brake rotors, SSAC products, Rotas, you
    Feb 05 2010
    Longmont Co
    its more the harness i want off first
    Feb 05 2010
    Longmont Co
    it broke but new came with clip and seal
    Feb 05 2010
    Longmont Co
    if i can get harness off i can use channel locks and grab sensor
    Feb 05 2010
    Longmont Co
    im going back for round three will be back hopefully not screaming to check thread
    Feb 05 2010
    Longmont Co
    know what? f this thing its getting dropped off tomorrow at mech ...i tried ....
    Nov 30 2010
    saint louis , MO
    Your gonna lose a quick $200. Make sure you don't have pieces of the old clips sitting in there. You also need to push down a bit on the sensor to get the clip to "click"
    Fuck those sheep. Fuck em hard. Do something right with your life.
    -Matador
    Senior Member Three Rings mooseclap05's Avatar
    Sep 16 2012
    Supercharged Tundra, B7 RS4
    Flagstaff, AZ
    pry harder but make sure the harness is safe from being bent or broken or what not, the harness could be brittle. the sensor is sometimes harder than you'd think to pry out
    Dec 05 2007
    My friend came over with his B5 S4 and we did his a couple weeks ago. For some oddball reason, the B5 S4 is a major PIA to remove that sensor. Best thing I can say is just keep at it. Keep the reservoir cap off and keep at it. You will lose a fair amount of coolant, but meh. We lost like 2 quarts, but I had extra.
    With the harness, spray some WD-40 on it to loosen that crud. Should make it easier to get the connector off. Push down on the connector (takes tension off the tab), pull the tab back, then pull the connector off.
    Sep 11 2009
    NE
    channel locks or something with super grab power or approach from the side and use a screwdriver to pry it out.
    Aug 13 2008
    Indiana
    Grab pliers, pull and twist at the same time. It's just the rubber o ring that's holding it up.
    -Nic
    Senior Member Two Rings CtS4Driver's Avatar
    Jan 24 2006
    2004 S4 6 speed sedan
    Greenwich, CT
    I used a right angle pick tool to free the gunked up old coolant that was crusted around the edges of the sensor by scraping around the edge where it meets the holder. That plus a pair of channel locks and a lot of cursing an wiggling the sensor back and forth finally got it out, though I probably spent more than an hour messing with it before it finally came out.
    Current: 2000 Imola 6MT sedan with Lots of goodies :)
    SOLD:2004 Imola 6MT sedan with milltek, RS4 reps, and H&R
    SOLD: 2000 S4 Silver Onyx/Silver alcantara
    APR chip,Milltek Cat-Back,
    UUC SS 40%, APR Bi-Pipe,SnubMount
    Forge Diverter Valves,K&N, ASA wheels, V1 Display installed in rearview mirror,Stoptech 332 Big Brake kit,Vogland suspension,OCT boost gauge
    Senior Member Three Rings ReDLiTe's Avatar
    Mar 24 2009
    Pittsfield, NH
    https://www.youtube.com/watch?v=BrbHpSczF9M
    ^that'll let you know you're not alone.
    My biggest tip would be to put on a good pair of gloves and try to rock the sensor left and right SLIGHTLY (don't break it) and it'll wiggle loose. Keep doing it for a while without losing hope. Push hard she'll come easy.
    When in doubt, when in fear, drop a gear & disappear!
    2000 S4 6mt Stock (dd)
    2000 S4 6mt Stage 3
    Veteran Member Three Rings ride1157's Avatar
    Jan 18 2010
    71 280sl, 16 g550, 22 RS6, 997.2 911T, 16 E63s AMG
    Palmer Woods Detroit
    I figured out the trick to getting these out EASY. BE GENTLE, get a flat head screw driver a short one if you have. where the clip goes in, slide the screw driver in there and push at the CTS at an upward angle "dig into" the CTS since its a more ductle metal than the screw driver you should be able to dig into it slightly to give you the grip u need to push it out. DO NOT scratch the pipe. you just need it to pop out a little and it will come right out. THe old oring expands and makes it really hard to pull them up and out.
    Feb 05 2010
    Longmont Co
    ok guys i will try tomorrow let you know ..thanks for the tips
    Feb 05 2010
    Longmont Co
    i will have better chance if i can get harness off wires are too brittle to hulk it
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I dont know what it is with those things! Either the oring gets petrified hard as stone, or melts into some kind of black goo (all from the dealer).
    Sounds like you have the former.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    Or just spray it with a little wd40, etc and wiggle. It helps a lot on some of these old o-ring and hose fittings.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Sep 11 2009
    NE
    pb blaster does wonders to any caked on rubber hoses, orings etc. Spray it, wiggle gently, spray, wiggle, until it let's go.
    Dec 05 2007
    Not a fan of randomly spraying PB Blaster onto plastic. Says right on the can that it does not fare too well with some plastics.
    Veteran Member Three Rings MLJS4's Avatar
    Jan 06 2010
    Michigan
    Just keep wiggling it it'll come out make sure you release all the pressure first
    2001.5 Stage III
    Established Member Two Rings TipsyTurtle's Avatar
    Jun 09 2011
    Boulder, CO
    Its kind of a pain but this is how i do it at work. open coolant res, release pressure, squeeze a coolant hose and while squeezing*** put cap back on res. now the coolant wont come out everywhere when you pull the temp sensor. to undo the clip, push down on the clip towards the sensor, then push the release button and pull up, you can also shove a small flathead into the mechanism to help release it. you can pb blast the old sensor but i wouldnt suggest putting it on the harness/plug. when you put the new sensor in, lube the o ring with vaseline or something similar to help it seat. you can also try grabbing the old sensor with needle nose pliers. good luck, dont pay someone its a PITA but not difficult, just frustrating.
    Last edited by TipsyTurtle; 12-20-2012 at 06:16 PM. Reason: god instead of good, sheesh
    shit happens. a lot.
    oh the B5...
    Sep 16 2012
    Flagstaff, AZ
    Quote Originally Posted by zillarob View Post
    thats what i thought but when i pulled mine out it was still an o-ring but had white coloration around it and in the pipe itself!! i wonder lol
    Nov 16 2010
    WetSide, WA
    Quote Originally Posted by TipsyTurtle View Post
    Nice! I usually use the airlift at ~5" or so.
    Veteran Member Four Rings rockcandy's Avatar
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    Pb blaster as someone said. What plastic are you worried about? I've used it on plastic stuff as well. I have never had it cause an issue. If the plastic had a heavy petroleum base to it it might cause issues but in my experience, not an issue on an Audi so far. This should be a 5 minute or less job, every time.
    Apr 20 2005
    New Hartford, IA
    It's not like you are gong to soak it for the next few years. Use it, remove the part, clean up the area, lube the new o-ring, done.
    If you guys don't want to drop fluids everywhere use a shop vac on the fill side of say oil, coolant, etc. It will pull air in once you open the system and not allow the fluids to drain out.
    02' Tundra
