Thanks coowhip. I guess I am more nervous / irritated than actually thinking. Being at work with not much time to really look at the car has me frustrated.. Ok, vent done!
So I rebuild it like 1.5 month ago. The original problem was my AMB cracked and all the coolant leaked from the head to the turbo. When I disconnected the exhaust manifold, I saw the turbo flooded and the manifold all wet. After the rebuild, the car has been running good and really all I had is the DTC: "Too rich (Add) / Too Lean (Mult)" which I think comes from having a vacuum leak. I have not driven the car hard and only cruise, but I do about 80miles daily.
About 2 weeks ago I started seeing a small dripping in the garage, but on the driver side. I think it was coolant as I saw the resorviour a little lower than what I expected so I fill it up. My plan was to fix all this little things over the holidays.....
Today I remember seeing quite a bit of white smoke coming from my exhaust in the morning. I thought it was the cold and normal, so I drive to work. When I turn on my car again is when I got the light for coolant and pop the hood to find the resorviour empty! I didn't feel anything wet from touching the hose from the resorvior down to the temp sensor in the bottom. Nothing wet in the thermostat housing. Coolant flange looks ok and nothing we on the top of the transmission.
Looking around I see the puddle on the passenger side. Need to determine where it dripped from. I will lift the car tonight and inspect. I am trying to figure out what to check.
So far I guess the plan is lift and turn the car on and check for obvious dripping.
Worst case, let's say is dripping in the GT2871r turbo (4 years old - and hard driven)... that's should be dripping outside unless is a seal or the hose it self.. right?
Oh.. I remember I should check the hose the crosses across the engines front. I will be back and check if level has changed after I refilled the resorviour. Good think I have a complete kit in the trunk to refill and fix the car.
UPDATE:
I don't see the resorviour has gone down since I filled it 4hrs ago. The puddle formed from the point I parked the car in only 1.5hrs.
