Results 1 to 7 of 7
    Jun 23 2009
    columbus ohio
    question about front window adjustment wedge
    I am changing out my front passenger window regulator clips and after reading the diys on the interwebs, I jumped on in. during the removal of the window frame from the door, I heard a metal part drop. After getting everything out I found a wedge at the bottom of my door. The front clip was broken (reason for this job)
    and I believe this wedge is connected into the window clip somehow. Found it strange that the wedge fell out, I would think it have a bolt/nut or nutplate that holds it in place.
    I could not find any mention of where this wedge connects, or how it is secured. It looks like it could fit on the t bolt clamping to the window
    Does it maintain position by pressure or is there a nut and bolt that goes through the center channel of the wedge?
    Thanks,
    Kevin
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    I don't know the answer to this....however....I did run into the same thing doing my window regulator as well - and I ended up leaving it out...
    No issues thus far without it...I don't think!
    Brilliant Black 2001 S4 - 6MT <3
    Sep 22 2009
    Vermont
    You mean the little aluminum shims? http://i.ebayimg.com/t/1999-AUDI-A6-LEFT-REAR-WINDOW-FRAME-SCREWS-SHIM-/00/s/NzY4WDEwMjQ=/$(KGrHqZ,!noF!Odv)g-kBQGwiyBBsQ~~60_57.JPG
    if it's those, they guy between two the door and the window assembly, they're held in place by the torx bolts, they're solely there for adjusting the position of the door so you're not left with a big gap between the car and the top of the door.
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by mr.awesome View Post
    This.
    There should be two torx bolts on the side of the door that hold the door frame to the door itself. This shim usually goes between the frame and the door on the bottom. It's to help with fitting the door up and making sure the window seals seat properly.
    Jason
    Jun 23 2009
    columbus ohio
    Ah that makes sense. The pic posted by mr awesome looks spot on. I can see the imprint the shim left on the lower forward torx bolt. I am waiting for the new ebay clips to be deliveried, but thought I would dry fit and see if I got it right. I attached a pic of the shim, does this look right, or is it backwards? I was hoping to see a lip for the hook on the shim to rest on or a channel it would ride in.
    I also found a thin metal shim on the aft bottom torx bolt but can see (from the paint) how that lines up
    Thanks for the quick responses, can't wait to get her back together.
    Apr 30 2014
    Asheville
    So is it easy to just replace the clips (orginally green- now white), without replacing the whole regulator?
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Dont think it is too bad of a job.
    http://www.regulatorfix.com/
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
