Hey guys, just looking for some opinions from people who have actually USED slotted rotors. I have seen so many opinions floating around on the web that it is starting to make my head spin. Some people say that slotted rotors cannot be turned, while others say they can, some people say they give an odd pedal feel and eat your pads really fast, etc.
Right now I have stock 1.8t brakes with centric premium rotors and stoptech street performance pads. No real complaints other than the fact that the brakes just aren't big enough and I would like to upgrade. I purchased s5 brakes for the front, so I am going to need to pick up b6/7 s4 rotors to fit up front, and have a line on some s4 rear calipers that would be going on at the same time as well. Should be a pretty good upgrade, however, I am just looking to get the best rotors the first time around. What I am mainly looking for is an increase in wet weather performance. Right now when I step on the brakes after not having applied them for 2-3 miles or more in moderate rain it feels like it takes about a full second to even start to do anything and doesn't get full braking power until about 2 seconds after I press the pedal. That makes me INCREDIBLY nervous in certain situations.
I have heard that slotted rotors can help eliminate that slow initial bite in the rain, which is the only reason I am considering them. I am NOT considering anything that has been drilled because they take away too much pad surface, can crack, I don't like the look as much as slots (although 0% of this upgrade is for looks, I am going for safety and performance 100%), etc.
So my questions are as follows, hopefully someone that has used both plain and slotted rotors while keeping their calipers consistent can chime in since I already know all of the hearsay and opinions on the matter:
Do slotted rotors really make a decent difference in initial bite/stopping distance in the wet?
Do they give you an odd or juddery pedal feel?
Can they be turned?
Will I really need them, or should going to s5 fronts and b6 s4 rears, and stainless lines be plenty? I am debating between powerslots or the centric premiums.
I would prefer if people that have experience with these issues chime in rather than just opinions because I have read about every speculative opinion under the sun on the issue already.
Thank you very much in advance!
