Results 1 to 13 of 13
Thread: Code wont clear
    Veteran Member Four Rings wannabeS4's Avatar
    May 14 2008
    01 S4 Avant
    New Hampshire
    Code wont clear
    So I am due for smog soon and have a cel. I scanned it and got this:
    17834 - EVAP Purge Valve (N80): Open Circuit
    P1426 - 35-00 - -
    So I got a new N80 valve, cleared the code and went for a drive. Cel came back on, scanned it again and got the same code . Is there anything else that can trigger this or is it in the wire harness?
    Brilliant Black S4 Avant
    #BODENARMY
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    P1426-- EVAP leak?
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    Open Circuit...? Make sure the N80 is plugged in.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    If you have already replaced it, I would fear wiring. If you have an ohm meter, 22-30 ohm to check the new one.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    May 14 2008
    01 S4 Avant
    New Hampshire
    Most definitely plugged in. Well I guess I am off to pick up an ohm meter in the morning. Is there anyway easy way to find the broken wire in the harness?
    #BODENARMY
    Nov 16 2010
    WetSide, WA
    If new n80 ohms good, lmk and I will look up the pinouts for you. Check the wiring near the connector and maybe even the ground on the head below-ish the n75 just for fun.
    Nov 16 2010
    WetSide, WA
    Forgot I already had these handy.
    Pin 1 grn/yel is +12v to fuse 34.
    Pin 2 pur/wht goes to pin 64 of the ecu.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    17834/P1426/005158 - EVAP Purge Valve (N80): Open Circuit
    Possible Symptoms
    Malfunction Indicator Ligh (MIL) active
    Possible Causes
    EVAP Purge Valve (N80) faulty
    Wiring/Connectors from/to EVAP Purge Valve (N80) faulty
    Fuel Pump Relay (J17) faulty
    Possible Solutions
    Check EVAP Purge Valve (N80)
    Check Wiring/Connectors from/to EVAP Purge Valve (N80)
    Check Fuel Pump Relay (J17)
    There are 10 kinds of people in this world, those who know binary and those who don't.
    May 14 2008
    01 S4 Avant
    New Hampshire
    Thanks for that, I was having trouble finding a wiring diagram. I also want to add I tried a used working N80 valve with the same results.
    #BODENARMY
    Nov 16 2010
    WetSide, WA
    That leaves "Check Wiring/Connectors from/to EVAP Purge Valve (N80)". If the fp relay were bad, you would have a shitload of other codes (and it wouldnt run).
    May 14 2008
    01 S4 Avant
    New Hampshire
    Quote Originally Posted by infinkc View Post
    Possible Symptoms
    Possible Causes
    Possible Solutions
    I've seen that, already checking two of the solutions. Wouldn't the fuel pump relay cause other problems such as no start and other codes.
    #BODENARMY
    May 14 2008
    01 S4 Avant
    New Hampshire
    Since I'm most likely going to be taking apart the harness; what is the best way to wrap it back up?
    #BODENARMY
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by wannabeS4 View Post
    why take the harness apart, check for connection from the valve plug to the ecu connection, if it shows open, then take the harness apart, or just run a wire direct to the ecu from the n80. also double check fuse 34 before you do anything.
