Results 1 to 40 of 44
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Was just at the dealer, and notice a Terra Clean machine for carbon build up
    I was just picking something up today and saw a TerraClean machine at the dealer, I asked them what it was, being the first time I've ever noticed it. It's their carbon build-up cleaning machine, and it's only $149 for a full clean on the Audi's he said. I remember reading a few threads a while ago on here where people have brought their cars to the dealer for carbon treatment and have been paying close to $500. I picked up a pamphlet and giving this some serious thought. Now I know there are a few DIY's floating around on how to do this, but for someone who has very little experience under the hood, this is probably safer and a better route for me.
    Has anyone tried this, or even seen one and heard of positive results? I spoke to the tech working there, and he said he does his car roughly every 2 years and notices an immediate difference. Something to look into. Here's their link
    http://terraclean.net/
    2008 A4 S-line 2.0T
    JHM Stage 2
    Veteran Member Four Rings yungcotter's Avatar
    Jun 09 2010
    Queens
    ITs probably similar to the BG treatments. Ive had it done on my car it I did get some results but the car did feel better. As good as a manual cleaning no but every bit helps.
    Edit: it actually looks allot more in depth. If they do all this for 150 thats a pretty good deal
    GDI Engine Intake Valve Deposit Cleaning Procedure
    This procedure requires a moderate to high level of technical expertise. You should not
    attempt this procedure until you have completely read this procedure and are thoroughly
    comfortable in executing it. Failure to follow instructions can lead to personal injury and or
    damage to engine.
    Wear Safety Glasses, Gloves, and Protect All Skin Surfaces as necessary.
    1
    Procedure will be most effective with engine hot.
    1. Remove shrouds, covers, wiring, and hoses as necessary to access intake manifold.
    2. Remove spark plugs.
    3. Remove nuts and bolts then pull away or if necessary remove the intake manifold from
    the block to allow access to intake ports (Note: In most cases pulling the manifold away
    from the block will be sufficient).
    4. Using a ratchet and socket (or other appropriate tool), rotate the engine until intake
    valves in cylinder number 1 are closed. (This should also close intake valves in one
    other cylinder)
    5. Fill canister of 201145 Pressurized Tool with TerraClean GDI Intake Valve Cleaner and
    reattach canister to the tool.
    6. Attach tool to shop air and set air regulator to 20 psi, then install nozzle tool to liquid
    hose.
    7. With nozzle tool in the intake port of number 1 cylinder, slowly open liquid valve on
    Pressurized Tool and carefully spray product into port until it is full of liquid, close valve.
    8. Follow same procedure for the other cylinder that has the valves closed.
    9. Wait five minutes (this will allow the chemical to work) and then using brass brush,
    vigorously brush port area and valve stems in cylinder 1 intake port.
    10. Do the same in the other cylinder.
    11. Return to cylinder 1 and repeat vigorous brushing and then go back to the other cylinder
    and do the same.
    12. Vacuum all liquid from ports.
    13. Inspect ports and valves (including valve stems) and if necessary repeat above
    procedure until all deposits are removed.
    14. Use shop air to blow out any remaining liquid and debris.
    15. After ensuring that all liquid has been removed from both, rotate engine until intake
    valves in the next cylinder in the firing order are closed. (This should also close intake
    valves in another cylinder)
    16. Follow steps 7 – 14 for the cylinders that have the valves closed.
    17. Repeat this process until all ports have been cleaned.
    18. After checking to be certain that all liquid and debris has been removed from all port
    areas, reinstall intake manifold.
    19. After checking to be certain that ratchet and socket have been removed, turn engine
    over with starter to be certain no liquid is left in port or combustion chamber.
    20. Reinstall spark plugs and then wiring, hoses, shrouds, and covers. 21. Add one bottle of Optima to fuel tank
    22. Perform TerraClean Fuel System Cleaning and Engine Decarbonizing Service.
    23. Clear codes if necessary and if applicable reset “Adaptation Values” to factory default.
    1
    In cases where engine is cold it is very beneficial to use an electric heat gun to heat intake port
    area prior to introducing chemical.
    -Theo
    2018 S4,Florett Silver, Magma
    2014 Q5, Phantom Black Pearl, Chestnut, 2.0T,Moms Ride
    2015 S4, Daytona Gray, DSG,Gone
    06 A4 2.0 T, Quartz Gray, Quattro, Tiptronic.
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    That's what I was blown away by, it was only $150... I'm thinking for that sort of change, it's worth a try. I bought a few cans of seafoam while I was out, but now considering just bringing those back and do this instead
    2008 A4 S-line 2.0T
    JHM Stage 2
    Oct 16 2008
    South Florida - Ft Lauderdale
    Nothing better than access the guts, and soda blast
    Phil
    Jun 09 2010
    Queens
    Phil Come to New york and do mine for me lol
    -Theo
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Yeah honestly, I would love for someone to come and do this for me. I'd much rather have a real scraping done.
    2008 A4 S-line 2.0T
    JHM Stage 2
    Oct 16 2008
    Quote Originally Posted by yungcotter View Post
    Fly me there and we do a WE cleaning with few cars
    Phil
    Senior Member Two Rings AdiDas's Avatar
    Aug 19 2012
    Pittsburgh, PA
    Phil
    count me in
    Jun 09 2010
    Queens
    Phil
    Do you mind flying coach?
    -Theo
    Oct 16 2008
    LOL not at all
    Phil
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    Ft/ Lauderdale to JFK.. Direct flight.. Should be about 200 bucks! Lol.. I fly through JFK to FTL all the time..
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Oct 16 2008
    Is it cold in NY? :)
    Phil
    Active Member Two Rings JTM14's Avatar
    Sep 15 2012
    B7 A4
    Glendale Heights, IL
    Interesting for the price.
    Under work
    Jun 09 2010
    Queens
    Phil
    Just a tad lol But i have a heater in the garage.
    -Theo
    Veteran Member Three Rings J.Owen's Avatar
    Aug 12 2010
    I run -361* of Camber.
    Bucks County, PA
    I would pitch in to ship Phil up here.
    Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
    Aug 19 2012
    Pittsburgh, PA
    Ill bring donuts
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    I went to the website and searched the cleaning procedures and it doesnt say anything about touching the intake...? It only references the fuel injectors.
    Veteran Member Four Rings Ed Gein's Avatar
    Sep 21 2011
    '10 GTI, '08 Scion tC, '01 CBR 600
    Maine
    do it op. cant go wrong for 150 bucks.
    Veteran Member Four Rings GarrettReid's Avatar
    Oct 26 2010
    Orlando
    Should Phil ever quit his day job, being an AZ prostitute might pay the bills.
    2014 Audi SQ5 Black w/Lava Gray and Magma Red
    SOLD: 2007 Land Rover Range Rover Sport Supercharged Black w/Black
    IG: GarrettReid
    Veteran Member Three Rings gdlkn84as's Avatar
    Apr 25 2012
    2006 B7 A4 S-line 2.0T (Sold) - 2008 PT Bruiser (Long Story) - 2003 Kawasaki Z1000
    Greenwood, IN
    Quote Originally Posted by PNW Avant View Post
    Looks like they have several options... fuel injection, intake valves, air intake. Be interested to see if my Audi dealer offers this. Have some seafoam lying around as well, waiting to be put to use...
    2006 B7 A4 S-Line 2.0T - SOLD
    -Making my return to the 'Zine-
    2016 B8.5 Allroad
    PP+, Sport Interior, DS, VAG'd
    2003 Kawasaki Z1000
    Oct 16 2008
    I started this not as a joke, I am real
    Let's talk after the holidays
    phil
    Active Member Four Rings Rodmar's Avatar
    Jan 29 2012
    None
    Minneapolis, MN
    Atleast Phil knows on hard times he'll have a place to sleep
    BB DTM B7 A4SOLD
    2015 Daytona Gray S4-Black with black Alacantra, B&O, Technology package, Carbon Atlas Inlays, RSD
    Parts on the car: AG M310 18", RS4 Grille, R8 oil Cap, roc euro intake, H&R Street Performance Coilovers, and awe exhaust with res. DP's
    Also in stable:
    2014 VW TDI SEL Passat
    Soon to be in stable:
    http://www.ebay.com/itm/Audi-RS4-Bas...178&rmvSB=true
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Did you see step #9 above. That leads me to believe there will be elbow grease involved.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    DMV Area
    Phil
    Phil, how much do you weight? Parcel post might be cheaper LOL
    - Chip
    K0R-GT -- S3 injectors -- Maestro tune -- IE Drop-in rods
    "It took 4 bad crankshaft seals and lots of cursing to build my avatar"
    Oct 16 2008
    Quote Originally Posted by shiro1745 View Post
    Doubt it = 210 LB of pure muscle
    Phil
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    At 183k miles and no carbon cleaning I might look in to this or the BG as long as we can put a boroscope in and take a look before and after.
    Veteran Member Four Rings IKE20VA4's Avatar
    Apr 08 2005
    Portland, OR
    Quote Originally Posted by chris@fifteen52 View Post
    Yeah I hear you on the boroscope part. I would want those before and afters for justification of my money well spent and that they didn't half ass it.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by IKE20VA4 View Post
    ^this!
    Jun 09 2010
    Queens
    Flat rate box lol. If it fits it ships
    Sent from my iPhone 5 using Tapatalk
    -Theo
    Jun 09 2010
    Queens
    phil
    I will Defiantly be in touch than.
    -Theo
    Jan 29 2012
    None
    Minneapolis, MN
    Phil could a personal mechanic lol not sure what you do for a living but I bet some rob guy could keep you around as their personal mech lol
    BB DTM B7 A4SOLD
    Also in stable:
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Re: Was just at the dealer, and notice a Terra Clean machine for carbon build up
    You guys should really take phil up on his offer. A couole of you guys split his travel/room/board and it would be much better money well spent. Quality job done by a quality mechanic, and spending quality time with an AZer. Can't beat that.
    Sent from my porcelain throne.
    2021 Audi S4, P34 Intake
    Jan 29 2012
    None
    Minneapolis, MN
    Ill do it in sd lol
    BB DTM B7 A4SOLD
    Also in stable:
    Veteran Member Three Rings mixtery's Avatar
    Jan 26 2011
    Out East
    Which dealer?
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    I'll definitely be needing before and afters as well.
    I'll probably have to wait until the new year before I get some time to bring the car in for this, I will post results when I can. Surprised no one else has seen or heard of it at their dealer, or it's the fact that no one here goes to the dealer anymore
    2008 A4 S-line 2.0T
    JHM Stage 2
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Phil
    Soda blasting still has the ability to etch into the finish of the valves. I would not do this to my car as you run the risk of etching into the valve seat area. I'd probably be more comfortable with other media.
    Veteran Member Four Rings Audi_509's Avatar
    May 20 2010
    2008 A4-sold. 2019 A5-sold,: '23 S5
    WA
    This.
    Aug 12 2010
    Bucks County, PA
    I use the dealership in emergency situations, but I have not seen this offered. I am sure it is, just not publicized.
    Veteran Member Three Rings midnight407's Avatar
    Oct 21 2011
    Brilliant Black B7, '06 STi borrowed/stolen from the roommate
    Northcenter/Ravenswood Chicago
    been googling it for almost an hour now, seems to be a ton of discussion, but inconclusive results. some people swear by it, some people think it's snake oil. can't find any before/after pics, though, and i think that's what really matters.
    midnight407
    Chicago, IL
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Yeah it definitely wasn't publicized, nor have they ever tried to push this on me. The only way I ever found out about it was walking around reading a bunch of different pamphlets and then I finally saw the machine in the back of the garage through the viewing windows.
    2008 A4 S-line 2.0T
    JHM Stage 2
