This picture is not mine, but the silver looking piece going diagonal is what I hit on the lift.
From reading a bunch of threads that piece of the exhaust is clamped together, I am hoping that the silver piece just banged the 2 pieces apart, and that I can simply loosen the clamp, push things together and tighten up the clamp again. If for whatever reason, the clamp is trashed (not sure how likely that is?) then is it something that can be picked up at Autozone? I am guessing it is just a standard exhaust type clamp and nothing special?
Obviously I don't know the damage for sure until I get home from work and get it up on ramps, but from what I can see so far combined with the much louder exhaust sound, and a putt putt sound from that area when I lean down besides the car, I am fairly certain it is this clamp. The flex pipe piece further towards the front appeared to be fine (again, kind of hard to tell with the car on the ground, but the sounds were from where the bracket is bent).
Seems like at least it should be a relatively cheap (possibly free) fix.
