Results 1 to 15 of 15
    May 21 2007
    Florida
    Anyone run 245/45/17 tires?
    Not that I want to, but one of my blizzaks went flat and I have to replace it due to sidewall damage. I found 4 used blizzaks that are 245/45/17 with decent tread for less than what 1 new blizzak will cost. Car is lowered, but not much at all as I raised about an inch for winter. The current size I'm running is 215/5017 which is not the right size, but it fits and rolling diameter is ok based on the online calculator I used. I know 45 is the right sidewall profile for 17s on this car but I don't know if 245 width will fit. Wheels are 17x7.5 et35
    2018 Navarro Blue Q5
    May 21 2007
    Florida
    Btw I searched and didn't come up w much in this size. Also on my phone so I can't scroll through threads as easily
    Veteran Member Three Rings swaggerwagon's Avatar
    Sep 28 2012
    NC
    I don't see why not? I'm running the stock 235/45/17. Don't see why you couldn't go a tad bit wider, it's only .3" more I think
    B8.5 3.0T/ B5.5 1.8T
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Won't be off by much, they might look a bit bulky on the stock 17s but there's people running that width with summer tires, you're increasing the diameter and width by about half an inch.
    http://www.tacomaworld.com/forum/tir...5r17-245-45r17
    I run the 215/50/17 winters as well, prefer narrower tire in the snow.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    May 21 2007
    Florida
    i ran this size more because i got them cheap on craigslist than anything else but ya narrow is better for the snow. my concern is that my wheels ARE NOT factory. Factory wheels have ~ET42 while the wheels i have are ET35 so i am 7mm closer to the fender. i feel like it will be close but i should be ok.
    Veteran Member Four Rings Shanster's Avatar
    Jun 02 2011
    2016 B8.5 Allroad, 2022 Volvo XC90 T8 Recharge R-Design
    Maine
    I have 4 blizzaks (WS-50) of varying tread depths. One is awesome, 2 are good, and 1 is terrible and not safe to use for winter use. You can HAVE them. I was thinking that I'd keep the awesome one as a spare, but my parents want them out of their basement.
    Take them all because you'll probably want to match the tread depth with the rest of your tires. They are size 235/45 R17.
    PM me if you are interested.
    EDIT: Tires are in Rochester, NH btw. I can meet you in Portsmouth or something early Saturday morning.
    Brent
    2016 B8.5 Monsoon Gray Alload
    Sold: 2007 B7 A4 Avant 2.0T 6MT, 2014 B8.5 Ibis White Alload
    May 21 2007
    Florida
    Quote Originally Posted by Shanster View Post
    you sir have PM! somehow i was able to find a used ws50 on ebay in that size but no ws60's in my size...wierd that an older tire is available...but in any case...ya you got PM!
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    While this is an awesome gesture, I don't think i'd want to mix match them with his 3 good 215/50/17
    Edit:
    2 on the front and 2 others on the rear might work.
    Checked it and it's only a 0.5% diff, i'd actually do it, i forgot that's why i went with the 215/50s in the first place it's almost stock diameter.
    http://www.tacomaworld.com/forum/tir...5r17-215-50r17
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    I'm running Ronal R37's with (i think) ET25 and 245/45R17 with no issues. I'm not lowered at all.
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    You dingus, they might stick out 7mm more but your fenders are rolled and you raised up your car. You'll be fine.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    May 21 2007
    Florida
    Yea I found an extra ws50 in 235/45/17 so ill just buy that and run all 4 the same!
    Quote Originally Posted by Exanimas View Post
    Fist yourself air ride queen
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by doublezero30 View Post
    haha amazing....
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    I'm running 245/45/R17 Blizzaks right now.
    Active Member Two Rings S6 Plus's Avatar
    Nov 16 2010
    AUDI A4 2.0TDI avant quattro, S-Line
    Ukraine / Kyiv
    Hi,
    I have two kits 245/45/17:
    summer: 245/45/17 with AUDI S6 C5 OEM wheel 4B3601025N 8.0x17ET35
    winter: 245/45/17 with AUDI A8 D3 OEM wheel 4E0601025S 8.0x17ET43
    Everything OK, not rub.
    AUDI S6 PLUS - DER WOLF IM SCHAFSPELZ
    Jan 28 2021
    Harare
    I also want ask a similar issue
    I have an Audi A6 C5 2.8litre
    Can i run 245/45 R17s on this car? Has anyone every done it before ?
