New member, first thread
Please help me!
Have a 2001 Audi a6 2.8l
Check engine light is coming on immediately after reset, p0056 and p0156 every time, Thought for sure that the o2 was dead, replaced it and the light comes back immediately with the same codes. I put my scanner on it and see all the fuel trims toggling and the o2 sensors moving. Bank 1 sensor 1 is leaning itself out while bank 2 sensor 2 will not move from .435mv. I checked at the ECM connector and I have voltage at the heater circuit (pins 1 and 2) which rules out fuses, and I'm showing .468mv and 55ohm at the signal wire. the ground wire to the ground on the battery is showing 1 volt and a half ohm. I am at a loss because I'm not sure what the signal and ground should be reading. But I figure it's correct since I'm not showing out of limit which would show a broken wire.
At the signal wires on the o2 sensor connector I have 10ohms which is also normal. Why am I getting no change in the signal?!?
