What's up audizine I had a quick question that I've searched an found different answers for. I have an 03 6 speed a4 3.0 v6 with 178k on it. About 2200 miles ago I changed my oil with German Titan synthetic oil 5w40 and today on my way to class my yellow not red warning light popped up on my dash (this has happened to me before) pulled into a gas station and picked up a quart of oil and added about 3/4 until the appropriate level was reached.
Now my question is, is roughly a quart every ~2200 miles is a bit excessive no? Even at this mileage. I change my oil with full synthetic every 3k as my mechanic recommend to me. There are never any oil spots under my car and the valve cover gaskets were replaced when I had the timing belt and water pump replaced. I asked my mechanic about it a few months back and he said not to worry about because the new b8s burn a quart every 1000 miles. I did a compression test on all 6 cylinders Over the Summer and across all 6 cylinders I had 180-190psi. Should I be worried? Will there be a 2.7t swap in my future? Hahaha
