Results 1 to 6 of 6
    Junior Member Two Rings
    Dec 11 2012
    Valley Stream New York
    Question Audi A3 with high miles (150,000)
    I am looking to purchase a 2006 A3 and found a nice one with a clean car fax, but it has 150,000 miles on it. During the test drive, I found the ac not working. I know the compressor on this model was problem, but is it any indication of the problems to come
    Veteran Member Four Rings singleframe's Avatar
    Apr 24 2010
    2007 Phantom Black RS4, VW eGolf
    Venice Beach baby!!! 🌞
    unless its a GREAT deal, not sure if I would pull the trigger. unless you got a garage and are a good DIYer.
    IG @myRS4 | 2007 RS4 | Phantom Black | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | K&N Filtered | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded | window trim matte black vinyl wrapped
    Oct 30 2006
    2011 GT3 RS, 2011 C63AMG, 2012 E63 Wagon, 2010 ML550, 2006 A3 commuter
    ca
    fsi motor?
    gotta see when they changed timing belt
    dv
    pcv
    cam
    cam follower
    cracked axle boots
    and the warranty for cam and cam follower is already over so u gona have to pay 3000 ish for new cam and cam follower to be installed if old one is bad.
    those are main things u need to check. if i were you i get a 2008.5+ with tsi motor. less hassle in the long run.
    Jan 07 2012
    Jacksonville FL
    Quote Originally Posted by tpliquid View Post
    fsi motor?
    dv
    pcv
    cam
    cam follower
    cracked axle boots
    ^ All of this, plus with this kind of mileage I'd start budgeting for a new turbo too. Is it DSG or manual? If DSG, check into when the trans fluid changes were done... should've been 40k, 80k, and 120k. You'll be due for another at 160k, expect to pay around $400 if done at the dealer. If DSG services have not been done, I'd be concerned as the extended warranty on that is up too.
    Check into the cost of getting the AC system fixed too. Compressor runs $400+ and they have to flush the lines and replace the dryer to do it proper.
    May 16 2010
    South Pasadena, CA
    If it's cheap enough, maybe you could rebuild the motor or drop in a crate motor. Stage III or K04 setup. I have almost 130K miles and my car is still running fine. I have done a lot of maintenance to my car and do show it a lot of TLC. If the previous owner does not have service receipts or logs, do expect to spend a few thousand in maintenance to take care of some of the common issues on these cars that some other people posted above.
    Dec 11 2012
    Owners moving and is willing to let it go for under 6000.00 US. It's a manual shift with no leaks or strange sounds. And it drives really nice. I haven't looked at the cam follower yet.
