Results 1 to 4 of 4
    Sep 18 2012
    vancouver,bc
    B6 A4 Avant Trunk Cabin light and Trunk lid light not working
    Hi Audizine,
    I am having problem with the Trunk light and the trunk lid light.
    I checked Fuse 24 and 38, they seems to be okay. I even switched a few around.
    Checked Light bulb
    The cluster detected that the trunk is open and closed ( so not the microswitch? )
    The red LED on On off button on the trunk light is working. ( the button lights up, but it won't turn the light on )
    I remember that the trunk light goes bad before the trunk lid light. Within 1 week, Now they are both not working.
    I find some water in the trunk light housing.
    Thank you
    Oct 30 2006
    B8 A4 Avant 6spd
    Could be switch itself, Ive seen them go bad on customers cars.
    -18 718 GTS
    Dec 15 2011
    Edmonton Alberta
    Check at the latch the microswitch has three wires going to it unhook it and check for damage/corrosion. If I remember correctly the wire are all ground to finish circuit so you ground each one to determine if it is the microswitch!
    -Richard-
    2009 Rabbit. 1961 VW Beetle Canadian Std. 2012 Ram 1500.
    Darsh Import/Dubsport Inc... My very own VW/Audi parts and service shop
    Certified VW/Audi Tech 20 years +
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Remove the entire light assembly and check the terminals for corrosion.
    -Doug
