Originally Posted by
aysix
I made a similar thread, but for an aquamist setup. A couple people including max@034 told me to do a triple nozzle setup.
This is only for Aquamist. Aquamist uses smaller nozzles, which helps resolution and control over flow better. Running 3 smaller nozzles is easier to fine-tune compared to one big nozzle, and helps with atomization.
For Devil's Own, you couldn't even run a single nozzle until recently as they only had up to D07 for quite some time, and I used two of those for GT's and my big single. They simply didn't have a single nozzle big enough. People also run the dual setup because it can be difficult to position a single nozzle before the TB but after the bipipes, although there's no reason you can't just one a single nozzle in one bipipe; everything is mixed in the plenum anyways.
Aquamist's smaller nozzles also allow more fine tuning of the actual peak flow, since you can run 3 different sized nozzles which gives you even more options. Aquamist nozzles also max out pretty low, so a big power car may max out the flow capability of two nozzles on an Aquamist.
We will be offering a "bolt on" AEM meth kit soon with dual nozzles and everything you need specifically for the S4, including a totally plug'n'play harness. No lines to splice or anything. The AEM is similar to the Devil's Own, but with some great extra features.
