Results 1 to 28 of 28
    Nov 23 2012
    West hills, CA
    B7 A4 Stage 2 APR: MOD RECOMMENDATIONS
    I just did stage 2 APR with Eurocode tuning's test pipe. I love how the car's running, but looking to do more mods. Does anyone have any other recommendations on what I should do next? Cold air intake or catback exhaust? I WANT MORE POWER for a good price! Thoughts and input please...
    I was also wondering if all automatic B7 A4's come with 7 gears? I was surpised when I got my car and it actually had 7 gears.
    Veteran Member Four Rings pat_do's Avatar
    Feb 19 2012
    Montreal
    Quote Originally Posted by Concepts77 View Post
    Next mod should be : APR or HPFP Upgrade Pump kit
    As for having 7 gears, you have a FWD B7. All Quattro Automatic has Tiptronic transmissions and only have 6 gears. FWD Automatics have a CVT Type Tranny and has 7 gears.
    Hope this helps.
    Senior Member Four Rings A410's Avatar
    Feb 29 2012
    2004 Pontiac GTO
    Baltimore, MD
    Did you try searching?
    2008 A4 2.0T Quattro / 3M Matte Orange Vinyl Wrap / APR Stage II+/ APR HPFP / RAI TP / RAI Catch Can / Custom RAI Exhaust / TR-11 FMIC / 034 Motorsports TIH / K&N / AudiUp Race Snub / 640 Mod / Various VAG Mods / New South Boost Gauge / R8 Coilpacks / NGK BKR7E / 200+ Lbs Weight Reduction / 19" RS3s / RS4 Rear Sway Bar / Coilovers / Cupra Lip / LED Taillights / 20% Tint /
    Veteran Member Three Rings vwnobby's Avatar
    Mar 30 2009
    '07 A4 S Line / '97 Jetta GLX (sold) / '96 FZR600
    Stage II I would recommend full exhaust and intercooler(s).
    2.0T MTQ | Revo Stage II+ | APR HPFP | 034 Engine Mounts | 034 HFC | 034 Turbo Inlet | ER SMICs | TT 2.5" DP | Magnaflow 16601 DP back | K&N Drop in filter | ECS Snub mount | RS4 Rear Sway bar kit | B5 lowering caps | "D" piston DV | TyrolSport Caliper Bushings | S4 Front Calipers/Carriers/Rotors | Goodrich SS lines | StopTech Street Performance Pads (Porterfield R4 for track) | AWE Vent Boost Gauge | NGK (4644) BKR7E (replaced NGK Iridium BKR7EIX-11)
    Jun 27 2011
    More power with the cvt is a recipe for disaster.
    Also neither a catback nor a "CAI" will give you any more power. They're sound mods not power mods.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Nov 23 2012
    West hills, CA
    Yeah, that helps. Thank you.
    Nov 23 2012
    West hills, CA
    Yeah, but the same websites pop up. Where do you get your parts from?
    Nov 23 2012
    West hills, CA
    I figured. Thanks.
    Veteran Member Four Rings slvrb7's Avatar
    Dec 28 2011
    2016 Polaris RZR 1000, 2016 Jeep Wrangler JKU, 2017 Range Rover, 2018 Land Rover Discovery
    North Texas
    False a true Cai will give you crank numbers but wheel numbers probably not, but they do cool better and weigh less then stock airbox. Also if you run something like aems the intake tubing is solid won't flex under boost.
    Kris
    Mar 26 2007
    Colorado
    you either want a HPFP & go stage 2+ or I would suggest a FMIC
    CURRENT:
    2021 Atlas
    Dec 28 2011
    North Texas
    I'm selling my upgraded dsmics from ER and my AEM intake also if you haven't upgraded to the rev d DV then you should I 'm selling that too. Or if you want to buy new search Google.
    Kris
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    I have a CVT also, full exhaust, apr stage 2, intake and front mount intercooler soon.
    Dec 28 2011
    North Texas
    If you do proper fmic then yeah go that route but ones like awe that block the entire radiatior I wouldn't.
    Kris
    Nov 23 2012
    West hills, CA
    Quote Originally Posted by slvrb7 View Post
    Thank you sir, i will look into that.
    Nov 23 2012
    West hills, CA
    How come youre selling them? Prices on the items?
    Nov 23 2012
    West hills, CA
    Quote Originally Posted by B72.0T View Post
    I'm having traction problems from a dead stop. Are you? I know part of it is because i need new tires. Where are you planning on getting the CAI and from mount intercooler?
    Active Member Four Rings Rodmar's Avatar
    Jan 29 2012
    None
    Minneapolis, MN
    Quote Originally Posted by A410 View Post
    I highly dobht it
    BB DTM B7 A4SOLD
    2015 Daytona Gray S4-Black with black Alacantra, B&O, Technology package, Carbon Atlas Inlays, RSD
    Parts on the car: AG M310 18", RS4 Grille, R8 oil Cap, roc euro intake, H&R Street Performance Coilovers, and awe exhaust with res. DP's
    Also in stable:
    2014 VW TDI SEL Passat
    Soon to be in stable:
    http://www.ebay.com/itm/Audi-RS4-Bas...178&rmvSB=true
    Jun 27 2011
    Concepts77: You're new here so I'll take it easy on you but a few things.
    1) Always use Reply with Quote as otherwise you're responses aren't clear who you're talking to.
    2) Search is your best friend
    3) check out the Quote icon with the plus just to the right of Reply with qoute. Its Multi-Quote. Its also your friend.
    4) Check out the classifieds here. If you notice, under peoples username and random info on the left of the posts, theres a link that says "My Classifieds". It will answer your questions about how muchslvrb7 is selling his stuff for...
    -CP
    2017 Q7 3.0t
    Nov 23 2012
    West hills, CA
    Thank you, I'm still getting accustomed with everything on the website.
    Dec 28 2011
    North Texas
    Chuck is right ^ look at my sig and that will explain why im selling parts. PM me as well if you want prices if you can pick up locally the better the deal you will get i don't know where west hills, ca is.
    Kris
    Jun 27 2011
    No problem man. Just some helpful tips! I didn't know about Multi-Quote for a while. When I figured it out though Mind = Blown.
    Also slvrb7, I want your ER SMICS but I don't want to pay for them. Can we work out a deal where you get my first born or something?
    -CP
    2017 Q7 3.0t
    Dec 28 2011
    North Texas
    haha possibly.
    Kris
    Nov 23 2012
    West hills, CA
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Any thoughts on the outside? Looking to get the door blades, buts so expensive for a set..
    Dec 28 2011
    North Texas
    get rid of sticker on widshield.
    Kris
    Dec 28 2011
    North Texas
    then vag out ambers.
    Kris
    Dec 28 2011
    North Texas
    next orange side markers.
    Kris
    Dec 28 2011
    North Texas
    lose dude in pass seat. ok im done sorry
    Kris
    Nov 15 2011
    Orlando, FL
    Those can be done with gloss shadowline tape :) - matches the BB pretty good.
