Results 1 to 11 of 11
    Veteran Member Three Rings Delasangre4231's Avatar
    Nov 22 2012
    Portland, Oregon
    3.0 Supercharger
    Would an OEM supercharger from a 2012 S4 or similar work on the 3.0 in a B6 3.0?
    http://www.ebay.com/itm/Audi-A4-A5-A...466151&vxp=mtr
    Established Member Two Rings RSicks's Avatar
    Jan 20 2012
    03 A4 Quattro 3.0
    Napa, CA
    Quote Originally Posted by Delasangre4231 View Post
    Highly doubt it, not even the same block. Only thing they share is that its a V6 and its 3 liters. Besides that, I don't see anything being the same.
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    It probably wouldn't bolt on, but you never know, you might be able to mod it to fit. It's probably the right displacement to be an effective blower on the 3.0, unlike the PES blowers, IMHO.
    -Tim
    Nov 22 2012
    Portland, Oregon
    I would like to get my hands on one and see if the bolt holes line up, then if they do see what some machinists say about making it work.
    Or i might just get an extra intake manifold and buy a generic blower and have it machined on.
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Money better spend on a 2.7L swap. Less R&D needed and yield just as good if not better power depending on build.
    RAI Test pipe / TT DP / S4 rear sway / Motoza stage 1 / SAI delete / IE Blockoff plate / S4 Front Recaros / B7 Center Console
    http://www.flickr.com/photos/27286038@N03/
    Nov 22 2012
    Portland, Oregon
    Yes yes, everyone keeps saying to turbo it. I refuse to go turbo, i just have a itch for a supercharger.
    Have you seen the new Vortech based charger JHM just released, im wondering if they are r&ding something for the 3.0...
    Veteran Member Four Rings Peacob's Avatar
    Jul 08 2009
    Bicycles
    Detroit MI
    If you have the itch to supercharge..... then i'd say go to a different car/engine.
    From my years on AZ and reading about the various engines... 3.0's are best left alone as daily drivers, and when they die, thats when people use the shells to do 4.2l or 2.7 swaps ;)
    That being said, i also feel like aftermarket support is a lot smaller, and in a sense, might be slowly dying. But honestly, what do I know as i've never owned a 3.0 and never really investigated what is out there and what is in the works.
    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    MK6 GTI, MK1 GTI 1.8T, B7 A4 TE Avant
    SLC, Utah
    No, that supercharger will not fit in any way. They are entirely different engines all together not to mention the design is utilized for TFSI with different heads and manifolds.... just no.
    -Tyler-
    Built 06A/IE Cams/IE 2.0 stroker/GT3076/6MTQ
    Dan Shank Super Tuned
    It was a fun run, but the time has gone.
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    Quote Originally Posted by nein-reis View Post
    not to mention there isn't a tune for it either so your car would ultimately run like shit even if you did get it matched up.
    May 11 2008
    Columbus, OH
    Don't count on JHM to put any more time than they already have in the 3.0 with new R&D. The tune they have along with down pipes is as far as they go I bet. Just not a great platform for big power.
    Nov 22 2012
    Portland, Oregon
    Well i emailed them a month or so ago and they had some power adders in development for the 3.0 but mostly they were working on the downpipes. If i can't get a supercharger going i think ill just wait and go for the 4.2.
    Actually while we are on the subject of motor swaps i was thinking about the 2.5TDI as a swap. What do you think of that?
