I've done lots of searching and have found good and bad on the KW Adjustable Springs. I was pretty sold on the H&R as so many of you have them and are happy but now my local shop is recomending the KW from personal experience (they sell both). He has been stating that he feels KW just has a better feel to them than H&R, granted thats on his M3. So, what I need are some guys to chime in, good and bad on the KW adjustable spring kits as I have ADS and am limited but don't want to be overly aggressive. I like that I could potentially raise the height in the winter if I wanted a bit more clearance but in reality would keep it the same year round, maybe a 20mm drop is all I need that way i can avoid potential alighnment requirements every season change.
I've seen a few Stasis and H&R kits that show slight sagging in the rear end, I would like to maintain a flat look as much as possible (no bodies in the trunk as it were). I think that KW would allow some fine tuning which is preferrable, and the less than 1 inch I'm after just to slightly stiffen the ride up, maintain ADS, and a bit better ride height for looks. That's my end goal. After scouring the forums I have heard a lot of happy folks and seen some good pictures of ride heights that I'm after but some have complained about sagging rear ends that need spring spacers, creaking (this would drive me batty), rear difficult to adjust without some dissassembly, etc.
Thanks in advance for your experiences here, especially for those with ADS and those that have gone between different brands, even if moving away from KW...what are your thoughts. Also, if using the KW set please let me know the approx drop measurement. I'm open to forum links or PM's as well but the more we share here the better. Thanks folks!!
