Originally Posted by
BITRBO
^IDK about that. When I worked at PepBoys way back when, they had a pretty badass battery/alternator tester would tell you to hold the RPM's above 2,200 (and then 3k) while it read/tested the system... Seems pointless if it charges at idle just the same.
It ALSO tests at idle conditions.......... You have to test both in order to actually do a thorough test on the alternator
Assuming you don't turn every single electronic load on that you can the battery will easily charge at idle.
Alternators these days are electronically controlled to provide the same amps from idle to full RPM.
Trickle charging would be better but in a pinch it's not necessary.
