Results 1 to 9 of 9
    Feb 03 2012
    Scranton, PA
    Changed plugs and broke ignition coil connector fml
    So, I changed to the high end plugs, got everything back together, CEL flashes, check codes, says no communication to coil #3, replaced coils and noticed the peice that the coil plugs into is broken. Can I find a replacement and just change the plug, or do I need the entire wiring harness?
    Jun 27 2011
    Some places sell a plug kit. I think they're like $25 or something.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 03 2012
    Scranton, PA
    Thanks! My local auto parts stores were telling me I needed an entire harness.
    Jun 30 2008
    Erie, Pennsylvania
    Here is the replacement coil pack connector housing:
    http://www.ecstuning.com/Search/4B0_973_724/ES10979/
    Technically, you need a special tool to de-pin your existing connector. I've had decent luck with using a sharpened paper clip and some "mad skillz yo". Using the correct tool definitely makes it less aggravating.
    Special tool (inexpensive version):
    http://www.ebay.com/itm/Lisle-56500-...2b79f1&vxp=mtr
    Modification to special tool to make it work better for these connectors:
    http://forums.tdiclub.com/showpost.p...8&postcount=34
    ^This thread also describes the paper clip method.
    Jun 27 2011
    http://www.amazon.com/2011340-Igniti.../dp/B004V2BPTI
    In case you like amazon.
    Though ECS is cheaper, surprisingly.
    -CP
    2017 Q7 3.0t
    Feb 03 2012
    Scranton, PA
    OK I got the new plug in, luckily it came with wires pre-attatched because the old connectors just fell apart. What is the pin out, because the wires on the car are different than the connector I got, on my new connector 1=black,2=brown,3=yellow,4=brown. I'm afraid to pull another connector apart, don't need 2 fk'd plugs. Thanks!
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    I'm going to go out on a limb here and tell you that you should probably just replace the entire harness. I don't know how many miles are on your car but most B6 coil pack harnesses are in rough shape at this point. 034 Motorsport sells a nice repair harness. And I ended up having to also replace my injector harness...because that was really deteriorating as well.
    Good luck man!
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by djsa4 View Post
    The colors don't matter. You take whatever wire went to pin 1 on your old connector and you connect it to...wait for it...pin 1 of your new connector. Whatever color that happens to be, it doesn't matter. Repeat for pins 2-4. Just make it happen, pin for pin.
    Feb 03 2012
    Scranton, PA
    The old connector was so brittle the wires just fell out so I have no idea what wire goes where, which is why i asked
