Results 1 to 18 of 18
    Oct 16 2012
    Pittsburgh PA
    Polishing Compound
    Hey guys. Anyone using Turtle Wax Polishing compound on their S5? I have some and just got a 2013 Monsoon Gray S5, and wanted to know if the Turtle Wax was safe on the Monsoon Gray paint.
    Feb 23 2012
    Northern California
    Im not an expert, but im pretty sure you shouldnt need polishing compound on new paint. The only time ive ever used it was to refresh old paint and/or remove very minor scratches, in both cases before waxing. If i was in your position i'd just keep the car clean and waxed. Repeatedly using polishing compound will wear on your clearcoat.
    -Doug
    '04 Ram 2500 (Work truck; too much to list)
    '01 allroad (Family transport; just getting started)
    Sep 28 2010
    NW NC / DE
    Yea, dont use that garbage. Adam's revive or Wolfgang paintwork polish enhancer is what you need.
    Oct 16 2012
    Pittsburgh PA
    I know I don't need it on new paint but I'm saying for minor scratches and things.
    Jul 25 2012
    Crozier, VA
    Mcguires Scratch X is better for touch ups. It's an abrasive that breaks down fairly quickly.
    Established Member Two Rings Troglodyte's Avatar
    Apr 28 2012
    Northeast
    Quote Originally Posted by Tvall13 View Post
    Never, always start with least abrasive and see what results you get. If you lack experience in polishing by machine or even by hand better to leave it alone you can do some serious harm. Here is my 2012 Monsoon Grey after very light polish with super fine abrasive, no where near a compound level. Finished up with sealant and good to go.
    2015 S4 Mythos Black
    Sep 28 2010
    NW NC / DE
    Show off;) Looks great.
    Apr 28 2012
    Northeast
    Thanks
    Just trying "to keep up with the Mops"
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    Re: Polishing Compound
    Quote Originally Posted by Troglodyte View Post
    What products? What pads if you used a machine?
    Sent from my SPH-L710 using Tapatalk 2
    Apr 28 2012
    Northeast
    [QUOTE=SlickMachine;8228334]What products? What pads if you used a machine?
    Flex 3401 and Auto Finesse Products (All products from Phil at Detailers Domain)
    1. Sonax Wheel Cleaner
    2. Wash (sprayed whole vehicle with AF Citrus, let dwell 5 minutes then washed)
    3. NanoSkin Autoscrub with Glide (super fast no reason to clay ever again)
    4. Polish with AF Tough Prep with white pad speed 3 on Flex 3401
    5. Two Coats AF Tough Coat applied by hand.
    6. AF Satin on Tires (1 Coat)
    Jan 07 2011
    2013 C300 4Matic
    Phil @ Detailers Domain!
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Oct 16 2012
    Pittsburgh PA
    Car looks great. So which product would you recommend for small touch ups? I've used to Turtle Wax for years on my old car (2008 Evo) but Mitsubishi's paint sucks so it didn't do any damage and did a good job of getting out any minor scratches (especially fingernail scratches on the inside of the door handle).
    Apr 28 2012
    Northeast
    You could try the AF Tripple which is a very light polish and wax in one step. If you want to wax after try their Rejuvenate or Tough Prep followed by Tough Coat like I did. These can be applied by hand, although it is time consuming. Menzerna makes very good polishes and they are available in various "levels' of cut. Without seeing / evaluating your car it is hard to say, but less is more, you can always go harder, but can not easily or cheaply put clear coat back. When you use a compound it will require additional steps to refine the finish back to the level you want. Try a "one step" it will clean, polish and protect and see what kind of results you get. Make sure you wash and clay before polishing to remove contaminants. Easiest solution, let a pro like Phil at DD do you car. Can't stress enough the idea of not trying something you are not comfortable or experienced at. Buy a polisher and some supplies and experiment on a junk yard panel or beater car, do not ruin your new Audi please. Hope this helps.
    May 21 2010
    Quote Originally Posted by JimWB View Post
    Exactly. DO NOT USE THAT TURTLE WAX COMPOUND!!!! Way too abrasive.
    Feb 21 2012
    Aurora, CO
    [QUOTE=Troglodyte;8228351]
    Quote Originally Posted by SlickMachine View Post
    Results are insane bro. Thanks for sharing.
    Mar 26 2012
    Kansas City MO
    I use Zymbol Car Wax. Works great.
    Apr 28 2012
    Northeast
    Wax does not polish or refine clear coat
    Quote Originally Posted by kwodem View Post
    Great wax indeed but does nothing in terms of polishing. In fact wax mutes the flake in metallic which is why I use Tough Coat to get as much pop as possible.
    Sep 28 2010
    NW NC / DE
    As mentioned, Menzerna makes great polishes. I have kept their intensive and finishing polishes on my shelf for many years. Intensive is great for the tough swirls but is quite gentle.
