Results 1 to 6 of 6
    Sep 07 2012
    Difference between auto and manual exhaust
    Hey guys, just so u know yes I've search but haven't got the right answer. Will a stock exhaust from a manual fit on a auto? I'm talking from the flex pipe back (not down pipe). Thanks for the help.
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    I havent looked into this either but i would assume yes. Just because that way audi only had to produce different down pipes rather than an entirely new exhaust.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Established Member Two Rings steven_1104235's Avatar
    Apr 21 2012
    B7 A4 2.0T Quattro 6MT
    Meriden,CT
    yes it does, the down pipe is the only difference. I was looking into the magnaflow 16680, it's listed for both FWD and quattro. Only certain exhausts like the APR are specific because they include a larger DP.
    United Motorsports Stage 1 Tune, Mesh Euro Grill, 19" TSW w/ Eagle F1's, Test Pipe, Custom CAI, Clutchmasters FX300, AirLift AirBag Setup V1 Management, OEM Roof Racks, Thule Fairing, Podi Column Pod w/ Boost Gauge, CC Mod w/ chrome bulbs, Wolo Air Horn
    Senior Member Three Rings Jhad's Avatar
    Aug 03 2012
    '11 Touareg
    SEPA
    Quote Originally Posted by steven_1104235 View Post
    True that its larger than stock, but to make the APR unit fit tip trans cars, all you have to do is grind off the bracket on the dp... ask me how i know .
    May 21 2007
    Florida
    the flex is part of the downpipe. so NO IT WONT FIT. from downpipe back will fit, but you would need to get the correct downpipe/flex pipe for your car based on which transmission you have! The magnaflow is listed as fitting both because it does not come with a downpipe like most exhausts.
    edit: i think i got confused with your wording and just repeated basically what everyone else has told you. lol
    2018 Navarro Blue Q5
    Sep 07 2012
    Sorry so yes an oem exhaust from a manual with the flex pipe attached will fit my auto??
