Results 1 to 12 of 12
Thread: N144 fault
    Veteran Member Three Rings Erwheezy's Avatar
    Jul 21 2012
    2015 eGolf
    N144 fault
    Scanned my car today to clear my check engine light, I had a hfc put in so I figured it was a fault for that. Pulled the codes and I got the efficiency fault and a fault for the engine mount. Cleared the faults but the engine mount fault comes back on right away. Car has about 7k miles and ill probably take it to the dealer. But I know I'll be flagged for td1 since I have software.
    Forgot to take a screen shot of the fault but its similar to this.
    005491 - Left Engine Mount Solenoid Valve (N144)
    P1573 - 001 - Open Circuit
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Do you have rough idle? That would be a symptom of bad mounts.
    They should be able to diagnose the failed mount without plugging it in.
    A bad mount will usually leak hydraulic fluid.
    Could be just a lose cable/sensor also as your car is so new.
    Bad mounts from past July. Was already flagged TD1 and Audi would not cover.
    -cW
    2023 X3 M40i Alpine White
    Jun 07 2011
    Arlington, TX
    Ouch, those mounts look bad. I too had to replace mine, which was an out of pocket expense... Close to $500 all together
    Go: APR 93 Oct Stage 1, Eurocode Trufit TIP
    Show: Tint, Glossy black plate filler, VAG-com, debadge
    Jul 21 2012
    2015 eGolf
    N144 fault
    Damn. Well Revo lied and they didn't have a flash available yet. So I'm going to the dealer now before I get my Stage 2 done. All I have now is the HFC cat so hopefully they won't TD1 my car
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    it's worth a shot. i just got a misfire issue solve for free even though the problem was absolutely not audi's or the dealership's fault. maybe you'll get lucky
    Present: 2010 Audi A4 2.0TQ Tip. Mods: APR chip, clear bra side mirrors and headlights, krautoparts.com interior/lic plate LEDs, and VAG COM mods
    Past: 2001 Audi A4 2.8QM. Mods: H&R race springs, CC mod, tinted tails, RS4 mirrors, ST chip, and VAG COM mods. Traded in
    2002 Honda Civic EX auto. Totaled
    Jul 21 2012
    2015 eGolf
    N144 fault
    Dropped the car off at the dealer today. SA just called me and asked if the ecu is flashed. We'll see what they find.
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    I had this error before... along with many other "open circuit" errors. Left my car at the airport and rabbits had climbed up into my engine compartment and went to town on the wiring. Turned into a $300 trip to the dealer to replace the harnesses and add braided steel.
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    Jul 21 2012
    2015 eGolf
    N144 fault
    Quote Originally Posted by auditd0rk View Post
    Damn. I hope that's not what it is.
    Jul 21 2012
    2015 eGolf
    N144 fault
    Double post.
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    Aghhh bummer. Hopefully things will work out well...
    Jul 21 2012
    2015 eGolf
    N144 fault
    Just got an update they're replacing the ECM. Whew good thing my ECM is still stock.
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    I replaced my (L) Engine mount two days ago and last night ran a VCDS scan and still getting 5394 - Left Engine Mount Solenoid Valve (N144) fault, you can see my old mount was toast
    [IMG][/IMG]
    My scan below, any ideas what to check, used Lemfroder mount made in Germany, looks like they are an OEM supplier on this part.
    1 Fault Found:
    P1571 00 [039] - Short to Plus
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 187963 km
    Date: 2018.07.19
    Time: 19:08:48
    I noticed fluid leaking out of right mount and have a 2nd mount on order, can the right side being bad cause the left side to Fault ?
