Results 1 to 17 of 17
    Established Member Two Rings Amm4's Avatar
    Nov 26 2012
    San Francisco, CA
    Tire pressure on 255/35/19
    Hello,
    I just put on S5 wheels 255/35/19 advan S.4. on my 2011 audi 2.0T quattro. I searched on google and forum, as well as looked into owner's manual. I've decided to go with 34psi in the front, and 33psi rear. I'm no expert in tires, but it looks flat... Here are some pics:
    Is this what its suppose to look like? If not, what tire pressure should i run? Thanks!
    Veteran Member Three Rings sickspeed's Avatar
    Sep 12 2005
    2001 S8 and 2011 Q7 TDI and 2010 Toyota Land Cruiser
    MD
    i think most people run a little higher than that, i.e., 35-40 psi. as for how it looks, i see what youre saying and i have the same tire specs on my stock s-line wheels but i think its probably a matter of the tire being somewhat wide or square for the size/width wheel. im guessing those wheels are 8-8.5" wide? if so, 255s might just be a bit meaty for that size wheel and causing the "flat" appearance youre referring to.
    2001 S8 or 2011 Q7 TDI Modded.
    Previous Audis: Red 1987 4000 CS, Dolphin 2002 A4 3.0 6MT Sedan, Atlas 2003 A4 3.0 6MT Wagon, Dolphin 2006 A4 2.0T 6MT Wagon, Meteor 2009 A4 2.0T Wagon S-Line .[/I]
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    38 front and 42 back is from factory.
    Dealership did 41 front and back on my last rotation.
    You are currently way too low....
    -cW
    2023 X3 M40i Alpine White
    Veteran Member Three Rings gunsmoker's Avatar
    Oct 24 2011
    Mansfield,MA
    -cW
    The factory sets a high pressure for a different reason. 38/42 is way too high. The wear will tell you if certain pressures are too high or too low for your average load and driving conditions.
    I run my 18" at 34/34 and haven't needed to rotate the tires for my 23k miles (mine is a quattro) and the wear is even front to back, side to center.
    The mid point between the full and normal load settings in the manual is always a good place to start. You can give it 1PSI up if the roads where you live are not great.
    2011 A4 2.0TFSI Quattro 6MT, Premium+, 18" Sport Package, Ice Silver, Light Grey, Dark Walnut, AWE Exhaust, STaSIS ECU Tune, Deval CF Splitter, aFe Pro Dry S Filter, ECode Turbo Inlet Hose, Alu Kreuz, Osir CF Valance, R8 Coil Packs, ECS Two-piece S4 Rotors, H&R Rear Sway Bar, 034 Trans Mount, RS5 Pedals, Ultra Racing Strut Bar
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    You are comparing 18's to 19's.
    The reason why the dealership service dept puts 41psi all around is because that is what is recommended on the door jam.
    -cW
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    My '11 Avant with s-line package came stock with 255/35/19, and the sticker on the door says 38 front 42 rear. That's obviously for a fully loaded car, but is at odds with the 35F / 35R recommended in the manual for fully loaded. FWIW, I do 39 all around, as it's generally a couple psi low by the next time I check.
    '11 S-Line A4 Avant
    '98.5 A4 2.8Q sedan retired after 14 years of service
    Veteran Member Four Rings jbradle7's Avatar
    Jan 09 2010
    GX460; MK7.5 GTI; WK2 Grand Cherokee; 73 Triumph TR5T
    St. Louis
    Dealership did 41 front and back on my last rotation.You are currently way too low....
    -cW
    This is what I run as well.
    Jan 09 2010
    St. Louis
    Quote Originally Posted by Amm4 View Post
    Quote Originally Posted by sickspeed View Post
    Visual appearance is a terrible indicator of a properly inflated tire, always use a tire pressure gauge to be safe.
    Veteran Member Three Rings hiwords1's Avatar
    Sep 13 2007
    PA
    idk what tire you have but i'd run at least 39. you want more air in your tires since you have less sidewall. it'll help absorb some of the shock over certain bumps
    Present: 2010 Audi A4 2.0TQ Tip. Mods: APR chip, clear bra side mirrors and headlights, krautoparts.com interior/lic plate LEDs, and VAG COM mods
    Past: 2001 Audi A4 2.8QM. Mods: H&R race springs, CC mod, tinted tails, RS4 mirrors, ST chip, and VAG COM mods. Traded in
    2002 Honda Civic EX auto. Totaled
    Oct 24 2011
    Mansfield,MA
    -cW
    I wasn't comparing 18" with 19", but it's beyond me why the pressures at the door are so high, given the reasonable numbers in the manual. What I meant was that the factory overinflates the tires to avoid flat spots before the sale.
    Nov 26 2012
    San Francisco, CA
    I'm running on 255/35/19 on 19x8.5 S5 wheels
    2011 B8 A4 2.0T 8Speed Quattro Premium Plus BLACK
    35% tint all around | S5 18x8.5 | Bright White LED Fog Lights | H&R OE Sport Springs | RS4 grille and mesh fog light covers
    2013 B8.5 S5 S-tronic Sprint Blue Pearl
    KW Variant 1 | HRE FF01 20x10.5 w/ Hankook v12 285/30ZR20 (5mm rear spacer) | 3M Carbon 35%F/18%R
    Nov 26 2012
    San Francisco, CA
    Thanks guys! I've decided to go with 39psi front and rear. Will post pics later to compare the visuals.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by gunsmoker View Post
    I also questioned this when I switched from 18s to 19s.
    The consensus from everyone including the service dept was to run it higher.
    Helps with stiffening side wall and protecting wheels...
    Anyway looks like OP has his answer.
    -cW
    Feb 15 2012
    Montreal/Quebec/Canada
    Always around 38 for me. I'm getting older and sport suspension is already stiff enough...
    2011 S4 Premium \\ Phantom Black \\ Lunar Silver leather \\ Carbon Trim \\ Sports Diff \\ Alufelgen SF71 19x9.5
    Senior Member Two Rings Big Nodge's Avatar
    Aug 12 2009
    New Hampshire
    Curious why people run even f/r pressure if factory recommends higher psi for rear? I have 255/35/19 and run 38/42 per door sticker. I was psyched to see the rear bias as I figured it was meant to compliment the 40/60 f/r torque split on the B8s awd system, and the weight distribution (battery in trunk, etc). Split was 50/50 on my B5 and B7 and the B8 is def the most fun on back roads.
    I guess for tire wear, but I rotate at winter swaps and that seems to be enough for my wear to be fairly even, so far.
    Nov 26 2012
    San Francisco, CA
    After driving around with 39f/39r, i felt a lot of road, I switched it to 37f/40r and the ride is much smoother.
    Here is a pic of my fronts (top pic 33psi, bot pic 37psi). I tried to get it at the same angle, but there is a noticeable difference between the two in person.
    May 08 2012
    2006 Suzuki SV650
    Atlanta, GA
    Quote Originally Posted by Big Nodge View Post
    Because the higher rear numbers are for full load conditions i.e. rear seat full of people and trunk full of cargo. If you look in the manual, it actually recommends slightly higher pressure in the front under "normal" load conditions, because the car does have a slight front weight bias. That shifts to the rear under fully loaded. The door stickers seem to only list the fully loaded pressures, probably just to be safe. I run even front/back as a compromise, since it's usually just me or 1 passenger, but I occasionally have rear passengers or cargo. If I were going on a road trip with 4 people and luggage, I would bump up the rear pressures.
    '11 S-Line A4 Avant
