Results 1 to 24 of 24
    Nov 28 2012
    cluj napoca
    power windows not working
    hello, have an audi a4 b6 model, and all power windows stopped working. I checked fuses, door wires, the wires from the comfort module and I found nothing.
    central locking work,door lamps work , foot lamp too.
    I did a test VAG-COM, but I did not found errors.
    I searched the forum but nothing helped me
    same thing happened in the past but recovered itself after few hours.
    Now I'm stuck with all the windows blocked and can not find any problems.
    some advices?
    Thanks a lot
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Well not the switches then. I assume the door is getting power if the other components are functioning (although I am not sure if there are more than one live wires feeding the door)--I'd think its a motor burnout issue. Time for a used motor from a donor car. Can you remove wires and feed it some juice to check?
    Senior Member Three Rings audiman18's Avatar
    Jan 22 2010
    '01 B5 S4 Avant - Laser Red Manual, ‘13 B8.5 S5 - Manual, '07 VW GTI Fahrenheit, 00 TT, 66 Mustang
    Medina, Ohio
    I've had it happen once... I checked and checked and found nothing wrong anywhere. I let it sit over night, in the morning still nothing. I disconnect the battery waited 5 minutes and reconnected it, everything worked and hasn't happened since. I've noticed our cars throw tantrums sometimes and you have to treat them like a child, let them sit in time out for a bit and try again... sometimes it works other times you have to use more discipline. Good luck hope that helps
    Veteran Member Four Rings airjordan223's Avatar
    May 04 2009
    Ohio
    Did you try each window switch, or just the ones on the driver door?
    2013 S4 | B&O | Sport Diff | Magma Red | DSG | LED Fogs| Stance SF03 | Michelin PSS | Gyeon Ceramic Coating | EPL Stage 1 | Maxton Design V2 | H&R OE Sport Springs | ECS Diffuser
    2002 A4 3.0 Quattro | 17" BBS RK | ST Coilovers | LED DRLs | Hardwired V1 | Alpine 12" Type R | Pioneer 800W Amp | eDead 80 | Dice iPod Integration | Power Slot Rotors | Hawk HPS Pads SOLD
    Nov 28 2012
    cluj napoca
    I tried all the switches on all doors and nothing. If I get down the driver's door module and connect the motor to power is ok.
    I will try to disconnect the battery for a while and then see if anything changes.
    I use VAG-COM measuring blocks and when pressed switches, VAG-COM shows manually open or auto open. So there is contact between door modules.
    what can I check next?
    Thanks to all
    Veteran Member Four Rings Myst420's Avatar
    Dec 07 2008
    02 Nissan Xterra
    Tampa
    Could it be the master switch going bad? and registering as if you have the windows locked?
    02 A4 Quattro 1.8T
    Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
    Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
    Nov 28 2012
    cluj napoca
    hello again
    I tried disconnecting the battery but nothing happened again.
    I remembered only that the problem occurred when making a diagnosis with VAG-COM. I was in the car, run the VAG-COM and opened the the window to smoke a cigarette. After I finished the test I disconnected interface and wanted to close the window but I could not.
    I took off motor window and got up the window manually
    something strange in all this.
    When this happened in the past, I was the same with the VAG-COM to look why not go heating in the passenger seat. But the next day I noticed that I could go down the window again. This time not happens and it's already been a week since
    Can the VAG-COM software to block something?
    thanks
    Sep 16 2010
    Central Wash
    Sounds like a broken wire in the drivers door jamb. Using VCDS Measuring blocks you should be able to read the state of each power winow switch- see if any of the switches are even registering a signal, eg; up/ down or nothing.
    A possible second guess is the CCM failure.
    I might be mistaken, but I think if the wire in to the drivers master switch breaks then none of the windows will work.
    Nov 28 2012
    cluj napoca
    hi rollerton,
    i try VCDS Measuring blocks and i can read the state of each power winow switch. All are okay.
    I wonder if it's a coincidence that they stopped when I connect the VCDS.
    CCM I think it works, closing works, the lights work, windows just stopped after a diagnosis with VDCS.
    any other suggestions?
    thanks
    Quote Originally Posted by rollerton View Post
    Nov 28 2012
    cluj napoca
    hi,
    here is a copy of the VCDS log:
    Saturday,01,December,2012,15:51:46:32264
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E85A074279 Mileage: 141290km/87793miles
    Address 01: Engine Labels: 03G-906-016-BKE.lbl
    Part No SW: 03G 906 016 HA HW: 028 101 221 9
    Component: R4 1,9L EDC 0000SG 9824
    Revision: 12345678 Serial number: AUZ6Z0D0261485
    Coding: 0000071
    Shop #: WSC 00191 264 15243
    VCID: 69D3A37D4362C31
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 4529
    Coding: 04255
    Shop #: WSC 10185
    VCID: E5CB2F4D7F7A671
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-10 - - - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AB
    Component: A4 Klimaautomat 1424
    Coding: 00000
    Shop #: WSC 06335
    VCID: 61C3BB5DEB528B1
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 F
    Component: int. Lastmodul RDW 0517
    Coding: 01011
    Shop #: WSC 00000
    VCID: 356B3F0D0F5A571
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0010602
    Shop #: WSC 06335 000 00000
    VCID: 3E7920216A6C949
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 N
    Component: Lenksáulenmodul 0911
    Coding: 00011
    Shop #: WSC 00000
    VCID: 3E7920213A6C949
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 900 M
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 00101
    Shop #: WSC 00012
    VCID: 2E591061EA0C649
    WAUZZZ8E85A074279 AUZ6Z0D0261485
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 AT
    Component: Komfortgerát T23 1412
    Coding: 06720
    Shop #: WSC 06335
    VCID: 830F11D5910EB91
    Subsystem 1 - Part No: 8E1959801B
    Component: Tõrsteuer.FS BRM 0205
    Subsystem 2 - Part No: 8E1959802B
    Component: Tõrsteuer.BF BRM 0205
    Subsystem 3 - Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0205
    Subsystem 4 - Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0205
    Address 55: Xenon Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D09
    Coding: 00060
    Shop #: WSC 06335
    VCID: 040D92C914003E9
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 D
    Component: concert II GRO 0004
    Coding: 04001
    Shop #: WSC 06335
    VCID: 2855E679C8E83A9
    End ---------------------------------------------------------------------
    are modules correctly coded?
    I have a aftermarke alarm installed on car.
    thanks
    Nov 28 2012
    cluj napoca
    nobody has any idea?
    Veteran Member Four Rings mauromj's Avatar
    Jul 22 2012
    Pullman, WA
    BUMP
    I recently took apart my driver side front and rear doors to pull the windows out and when I put them back in and plugged the motors back in, I cannot roll down any of the 4 windows or the sunroof. In VCDS, I am able to see the switching working when i assert/de-assert them. I checked the door harness wiring and 3 wires had cracked insulation but the wires were still in tact and showed voltage. Does anyone have any idea of whats going on??
    2021 Q5
    2018 SQ5
    2012 S5
    2003 A4
    2000 S4
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    chances are you have a broken wire if there is cracked insulation. At the very least a a high impedence from a crappy connection which will cause all kinds of gremlins in the wiring (like the appearance of a good connection but not working).
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Veteran Member Four Rings Evan1028's Avatar
    Mar 23 2015
    2009 Audi Q5 Prem+3.2L V6 Quattro Meteor Grey
    Latrobe PA
    Back from the dead, I have a similar issue. My passenger front window will work numerous times and then I come back later in the day and get in the car and it wont move. When the window does work, it is quiet as can be and that would lead me to think it is not the regulator. I have also replaced drivers master and passenger switches but the problem still persists. I actually bought a used motor as well and it was still not going down. I honestly have no clue why this is happening. It is so sporadic that it is hard to pinpoint a reason for this. It isn't a nusance but it can be frustrating especially when I want to vent the car of it's 100 degree air on the hot day like today! Any tips will be mucho appreciate, thanks homies!
    Jun 30 2014
    johannesburg South Africa
    Same issue here... Been stuck like this for a week now. All fuses, relays and wiring is good. I had the ccm tested by an audi Indi, and all checks out. At a total loss.
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Did you guys check the window regulators?
    "Beep beeeep bloop boop" - R2D2
    Jun 30 2014
    Yep, they checked out fine. It is like they are just not getting power for some reason, but all fuses and wiring is fine.
    Jul 31 2014
    NH
    Sounds like the relays in the ccm may be bad. Checking the module with a pc wouldn't show this.
    Active Member Two Rings Sodium's Avatar
    Dec 25 2015
    '06 A4 Avant Quattro 3.2 FSI, '95 Jaguar XJS convertible, '95 Diesel Dodge (Train Driver)
    Austin, TX
    So yesterday without warning my car started making a loud BEEEEEP from the back by the fuel fill.
    Then the windows stopped working. The fuel fill wouldn't open. The key fob wouldn't lock the car anymore.
    The tone stopped. The fuel fill still won't open (manual release) and none of the window switches operate the windows.
    Seems similar to what you're looking at here. Anyone have ideas of where to check, what to reset?
    Dec 25 2015
    Austin, TX
    Well drat. I got the carpet up and there's water down there and the CCM was clicking. The water got into the box for the device too so I popped it out of there and got the circuit board out of the case. Fortunately, the water inside the CCM was pretty minimal. The corrosion was almost entirely on the circuit side, the component side was immaculate.
    So I'm taking a pencil eraser, kebab skewers, WD40 and patience and removing all of the corrosion spots and I'm hoping that nothing burned out when it shorted out. Wish me luck.
    Now I'm wondering where the water came from. My best guess is a plugged AC condensate drain. The AC has been running these last few weeks. So I need to go hunting to find that while also getting the water out and getting it all dried up. It's supposed to pour rain later today just to make matters more interesting.
    Dec 25 2015
    Austin, TX
    Well damn. I must be living right.
    Cleaning the board up, I really had to get in there with the kebab skewers to dig up some of the corrosion between solder joints, and spraying the harness down with WD40 worked the magic. My CCM is back in business. I've put the board back in the housing and then run a bead of permatex black around the seam to seal that up tight. I'm going to liberally apply diaelectric grease to the connectors before refitting them once the permatex is dry and also seal up the wiring run into the water tight case housing the connectors and CCM. It has a nice rubber seal but the wiring harness passes through a large grommet. VAG applied some RTV or silicone or something to the wiring at the grommet but did a piss poor job on quality control and it's leaky.
    Honestly, this is clearly a manufacturing defect. VAG seems to have understood there was the potential for moisture and made efforts to seal the housing against moisture. But their efforts were sloppy at the wiring harness penetration and consequently it didn't work and water can enter the waterproof housing easily. Questionable placement of the component too I might add but the clear defect here is the poor job sealing the wiring harness against moisture leaks.
    - - - Updated - - -
    I still need to find the AC condensate drains and hook a shop vac to them and assure the are clear and free.
    Dec 25 2015
    Austin, TX
    I had a chance to tear down an '07 A6 at a junk yard recently and intended to grab the ECM cover to replace the broken-and-patched cover on my A4. Low and behold the A6 had a completely redesigned ECM housing that included rearchitecting the firewall entirely so that the ECM cover was directly accessible without removing the wipers, did not sit over a wiring run in the firewall and did not have the windscreen water runoff pouring over the cover.
    Given that the A4 and A6 have the same engine and virtually the same feature set I'm going to guess someone noticed this insane design "feature" and fixed it in the redesign.
    Dec 12 2016
    Paris France
    Hi,
    Did you find the issue ?
    I am in the same situation.
    Before the windows completly stopped working it happend around 4 times to either not open or not getting it up , they started working after around 30 min of driving.
    When they stopped working for good , I left my home , after 10 min I tried to open , no response , after another 20 min they worked fine while running the car wheels . When I stopped for parking to get the entrance ticket i pressed down the button, the window responded but after that it did not come up anymore. From that point after getting home i manually got it up but could not get down anymore so all windows blocked up now.
    I scanned it with vcds, everything is clean, no errors.
    I checked fuses, continuouity of wires, main controls on the doors are lighten but none is operating.
    I woul appreciate any guidance.
    Thank you
    It is an audi a4 b7 1.9 tdi 09/2006
    Dec 12 2016
    Paris France
    Quote Originally Posted by valentin View Post
    hi rollerton,
    thanks
    Hi,
    Thank you
