16725 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 004 - No Signal/Communication
- Swapped in a new cam position sensor, no change
- Verified timing marks on crank / cam gears, both line up 100% perfectly
- Verified cam timing marks (notches) line up with arrows on bearing caps - both line up (notches to arrows)
- Tested cam position sensor wiring. The 5v & 12v lines read correctly, and the black wire shows no short to battery / ground / etc
- Tested cam position sensor with LED test light, it 'flashes' in accordance with the engine
- Checked the cam position sensor shutter wheel. The tab that locates it had gotten bent previously (DSPO), I fixed it & lined it up correctly. No change.
Its still throwing the code & acceleration off the line is very sluggish. It runs fine at highway speeds, but its an absolute dog starting off. I usually have to try to start it 2-3 times before it'll catch.
Any other ideas? I'm coming up blank on this one...
